| Home > Help Needed / General Tech Chat > Inlet manifold servo take off thread damaged. | |||||||
![]() 300 Posts Member #: 1746 Senior Member Kent |
28th Nov, 2009 at 06:26:33pm
Well i brought a metro turbo inlet manifold the other day and i had a good look at it today and the thread the servo take off banjo bolts to is damaged.
28th Nov, 2009 at 06:33:37pm
Can you make an alloy boss with the correct thread and weld it in? I seriously doubt it! |
28th Nov, 2009 at 06:42:36pm
Sounds like a good idea, but iv not got anything that i can weld ali with, iv only got a mig...
28th Nov, 2009 at 06:48:10pm
The flanges are different thickness so you would have trouble bolting the manifolds down On 11th Feb, 2015 robert said:
28th Nov, 2009 at 07:01:29pm
Apart from that flanges being different thicknesses, does the manifold physically fit about the turbo manifold?
969 Posts Member #: 47 Post Whore Not very sunny swanage |
28th Nov, 2009 at 07:15:12pm
got it in my head that a n/a manifold wont fit above the turbo exhaust manifold....
And on the 7th day........... God created turbochargers! |
28th Nov, 2009 at 07:38:00pm
Even if it does fit (not sure) you would have to modify the bolt "half" holes as well as making the stepped washers.
Edited by Rod S on 28th Nov, 2009. Schrödinger's cat - so which one am I ??? |
28th Nov, 2009 at 07:51:45pm
Thanks for the information Rod.
28th Nov, 2009 at 07:53:32pm
Araldite it in.... sorted. On 28th Aug, 2011 Kean said:
1300 Posts Member #: 829 Post Whore essex |
28th Nov, 2009 at 08:10:45pm
On 28th Nov, 2009 tomf said: if you have the banjo bolt take it to a nut bolt shop a buy a hle coil kit it will come with a tap and coil to re tap it back to std thread
Well i brought a metro turbo inlet manifold the other day and i had a good look at it today and the thread the servo take off banjo bolts to is damaged. Im not sure how its been damaged, but there isnt any of the threads left. Whats the best way to repair this? I did think about drilling it out and tapping a new thread, but i dont have a tap that big, also it would mean i would need to get some new servo pipes made up with a larger banjo fitting... Any advice would be great, if not ill have to just search for another inlet :( 1293 Turbo mini
28th Nov, 2009 at 08:13:13pm
Has anyone every used this stuff
28th Nov, 2009 at 08:29:04pm
i would of sad that it is a load of sh*t because you are going to lay the metal on the maniford and you will still need to tap it out a coil kit is about £30 1293 Turbo mini
28th Nov, 2009 at 08:38:51pm
Ah sorry i must have been writing my post when you posted.
28th Nov, 2009 at 09:00:21pm
Helicoils are a good solution but 95% of the cost is in the special tap and the fitting tool, the actual inserts are cheap.
28th Nov, 2009 at 09:37:12pm
it's defintately a similar size to the crank thread as i used to plug my inlet with an old pulley bolt. On 20th Oct, 2015 Tom Fenton said:
28th Nov, 2009 at 11:43:13pm
Dont you know a local engineering shop? Take it to them and basically "Ask" someone can fix it 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
29th Nov, 2009 at 01:01:35am
You can mig ali on your DIY Mig machine if you change the wire over to ali (about £15 for a small 0.8mm roll from Hallfords) and use pure argon (again, Halfords, about £8).
