Home > Help Needed / General Tech Chat > what dizzy should i use ?
turboaseries!!
Member #: 7596
wondering if there are any better distributor options for a turbo engine before i can afford the megajolt system, or is the standard turbo one good for the job ?
on booosttt
yes use the standard Turbo dizzy it realy has a "shade" too much advance 28 deg max advance
time the engine in at 1000 rpm and 6 deg BTDC Vac disconnected
turboaseries!!
Member #: 7596
ok cheers ben
on booosttt
