| Home > Technical Chat > machining head for dry deck pipe | |||||||
124 Posts Member #: 1126 Advanced Member peterborough |
30th Nov, 2009 at 03:20:06pm
Anyone seen a decent scaleable pic of the end of a head thats been modded? was gonna have a go at doing it myself but dont really know where it should be machined flat or how big the hole should be.
30th Nov, 2009 at 03:28:25pm
starts from post 22 i think these are the best set of pics i have seen
Yes i moved to the darkside |
30th Nov, 2009 at 04:10:12pm
Perfect :0)
1st Dec, 2009 at 11:56:50am
does anyone have these pictures available to post here?
1st Dec, 2009 at 12:18:20pm
ill get them for you
1st Dec, 2009 at 12:23:21pm
there not hosted here as i tend to break turbominis when i upload Edited by Brett on 1st Dec, 2009. Yes i moved to the darkside |
1st Dec, 2009 at 04:37:25pm
only managed to get 1 before it started to say error you must be a member but its def the best scalable image, squarest to the cammera. will post asap. |
1st Dec, 2009 at 04:43:58pm
1st Dec, 2009 at 05:23:22pm
.. On 26th Oct, 2004 TurboDave16v said:
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
1st Dec, 2009 at 05:31:46pm
I did mine a different way. The head was drilled & tapped & the core plug was tapped.
1st Dec, 2009 at 05:39:14pm
out of interest, what thread did you use phil? "Turbo's make torque, and torque makes fun"
1st Dec, 2009 at 05:48:01pm
IIRC it was an 1-3/8" tap, can't remember what thread. |
1st Dec, 2009 at 06:51:53pm
did wonder if it was possible to do it like this, very neat and a lot easier to achive without a mill.
1st Dec, 2009 at 09:46:11pm
Whats the girth of your pipe phil? |
1st Dec, 2009 at 11:50:23pm
nic, i can tell you right now its 28mm, and bent 180....nothing to brag about... "Turbo's make torque, and torque makes fun"
2nd Dec, 2009 at 12:00:26am
Doh yes!!
3rd Dec, 2009 at 10:52:12pm
found a 1 3/8 unf tap no probs, under a tenner on ebay. Die however is £60!!!!
