| Home > Help Needed / General Tech Chat > Dump Valve location | |||||||
![]() 300 Posts Member #: 1746 Senior Member Kent |
2nd Dec, 2009 at 11:13:09pm
Well i have tried searching but couldnt find anything so thought i would ask.
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
2nd Dec, 2009 at 11:56:07pm
The closer to the Plenum the better! I believe its to relive the excess boost from the butterfly as soon as possible? |
3rd Dec, 2009 at 07:52:30am
Before the intercooler is better. On 13th Jul, 2012 Ben H said:
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
3rd Dec, 2009 at 09:43:51am
On 3rd Dec, 2009 Vegard said:
Before the intercooler is better. ive put mine before aswel so you dump warm air, and i thought the idea was to relieve pressure from the turbine to reduce stalling not the butterfly? |
3rd Dec, 2009 at 09:53:36am
Me too. |
3rd Dec, 2009 at 10:06:34am
the reason people say close to the butterfly is to minimise airflow reversal but the downside of it is that insignificant it doesnt really matter (as most of the time it gets dumped anyway) at really high boost it can cause problems though
Yes i moved to the darkside |
3rd Dec, 2009 at 10:27:12am
Surely 90% of TM setups have the dv after the intercooler though next to the butterfly? |
3rd Dec, 2009 at 10:31:41am
I thought that too Gav. I remember someone tried using the dump on a cossie cooler and had problems. Can't remember who though now. If something is worth doing, it's worth doing half of. |
3rd Dec, 2009 at 02:42:48pm
Mine is also going before the intercooler on the logic it's there to protect the compressor against stall.
3rd Dec, 2009 at 03:01:06pm
Mine on the cossie intercooler take off pipe. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
3rd Dec, 2009 at 03:21:10pm
mine's in the bin On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
3rd Dec, 2009 at 04:06:11pm
Isn't the initial back pressure generated at the butterfly as the throttle closes, so the ideal place to relieve the back pressure (have the dump valve) is as close to here as possible; on the plenum chamber?
3rd Dec, 2009 at 05:11:59pm
No, because it isn't the back pressure that operates a DV, a DV is operated by vacuum pulled in the inlet manifold after the throttle plate as soon as the throttle plate is closed (carb or injection) so to protect the compressor, the fastest way to lose pressure at the compressor is to have the DV there. As air is a compressible fluid and there will be lots of pressure drops around the system (especially the intercooler) the pressure will not be lost everywhere at the same time.
3rd Dec, 2009 at 05:16:30pm
Most of these theories are pretty sound in one way or another.
3rd Dec, 2009 at 07:16:28pm
Ah that makes some sense - hence the Ø6mm pipe that runs from the DV to the inlet, yes. Hmm, I'll have to have a re-think about that now!
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
6th Dec, 2009 at 10:29:10am
i have mine on my plenum! cheers nic On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
6th Dec, 2009 at 08:37:42pm
The standard dump valve on my scooby is on the outlet of the intercooler, which is just before the throttle. Edited by metroturbo on 6th Dec, 2009. |
388 Posts Member #: 442 Senior Member Manchester |
7th Dec, 2009 at 07:02:48pm
On the Z20LET's the OEM valve is on the compressor of the turbo itself.
7th Dec, 2009 at 09:16:56pm
If one fits the DV after the intercooler, be at least as smart as to route the air into the hose between the filter and turbo inlet.
7th Dec, 2009 at 09:29:00pm
On 3rd Dec, 2009 rubicon said:
mine's in the bin Exactly what I was going to say
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
8th Dec, 2009 at 07:52:38am
V I like your thinking. . . . . . .. . . .off to Ebay
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
25th Feb, 2010 at 04:54:18pm
on my 20vt A3, the standard dump valve is often upgraded to a piston type valve, which as standard is mounted before the IC. these tend to overheat, causing them to stick. it's also not great as it recircs hot air back into the system.
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
