| Home > Help Needed / General Tech Chat > How you pipe a bleed value | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
24th Dec, 2004 at 07:28:23pm
how you pipe up a bleed valve i know you get one pipe from the turbo but wheres it go on the bleed valve and where do other pipes go to and where do they come from?? |
25th Dec, 2004 at 11:09:47pm
the bleed valve has 3 connections... the outer 2 are connected between the turbo and the actuator...in line..
25th Dec, 2004 at 11:09:53pm
Anyone got an idea ??? |
25th Dec, 2004 at 11:18:26pm
how much can you turn it is there a set amount like two turns or something???
26th Dec, 2004 at 12:13:53am
the pipe that goes to the actuator is the one you put throught he bleed valve, the other one is where the boost solenoid used to go so block it off.
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
26th Dec, 2004 at 12:39:09pm
If your engine is totally standard i wouldn't think about upping the boost much. You can't run more boost without altering the fuelling/ignition to suit, then there's the compression ratio to consider ..... You MAY be able to get away with retarding the timing slightly and richening the mixture, but you're still limited by the compression.
26th Dec, 2004 at 09:57:50pm
i was going to add an intercooler anyway but i didn't really want to do anything else so you think theres no point then so if i put it on it wouldn't give me any thing??? |
26th Dec, 2004 at 10:45:04pm
if you put it on and keep it closed it wont do a thing.
![]() 1128 Posts Member #: 142 Post Whore Winchester |
27th Dec, 2004 at 04:07:18pm
amen brother |
27th Dec, 2004 at 04:52:58pm
Personally I like to place a small (FLOW REGULATOR) in line, coming from the first pipe from the pressure side of the turbo up to the three-leg valve.
Edited by BENROSS on 29th Dec, 2004.
30th Dec, 2004 at 01:01:02pm
Yes I agree with Ben this is a good idea, as it also will allow you to set max boost using the flow reg, and so then there is no danger of damaging anything over adjusting the bleed valve.
30th Dec, 2004 at 02:59:19pm
Hi Tom, Edited by BENROSS on 30th Dec, 2004.
30th Dec, 2004 at 03:25:41pm
yeah you are right I have just engaged brain and thought about it.......
