Home > Help Needed / General Tech Chat > Dry Decking (Oil Feed)
I've been thinking abour dry decking my engine when it comes to build time.
However I can't find any information about whether or not to block off the oil feed and feed the head/rockers etc another way?
Do most people just dry deck the water and leave the oil alone?
I know the oil will return down the pushrod holes so I can't really see a reason not to leave standard oil feed in place.
advantage998
Member #: 1840
Kings Lynn, Norfolk
AFAIK its just the water ways which are blocked, as the oil feed is far enough away from the bores to cause any problems.
I've have left the oil fed as is on my twink build.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I am not sure its a good idea to leave the oil feed as is on the twink build. You should move it slightly to make them match. Also its a good idea to machine the jackshaft to give a continuous feed of oil to the head. More about that on EFIminis.
jackshaft being the now redundant A series camshaft thats retained to drive the oil pump?
Edit, i think for simplicity mine will be staying from the standard feed point in the block
Edited by Brett on 4th Dec, 2009.
advantage998
Member #: 1840
Kings Lynn, Norfolk
My K head has been machined to ensure the feeds line up corectly. Will look into the jackshaft mod, thanks.
Note than John now has level 3 TM Disease. From our conversations today, his cooper may end up an out and out racer *hehe!*
I am ill! I feel the need for carbon fibre, aluminuim and holes!!!!
stefaz
Member #: 1656
stoke-on-trent
What about polycarb windows John?
Stop it!
