| Home > Help Needed / General Tech Chat > engine still run on after switch off | |||||||
100 Posts Member #: 7614 Advanced Member Malaysia |
5th Dec, 2009 at 12:52:27pm
i have this problem with my car.
http://www.minimonstermotorsport.blogspot.com/
5th Dec, 2009 at 01:14:27pm
It's a common problem with some A Series engines. Hotspots in the cylinder head acting like a spark plug. The way Leyland/Rover got over it on some of the Metro models (ie, MG Metro) was to install an anti-run on valve, basically a solenoid operated valve connected to the inlet manifold which was shut with the engine running (ignition on) and openned as soon as the ignition switch was turned off allowing the engine to suck in a load of air rather than the correct mixture from the carb. Schrödinger's cat - so which one am I ??? |
5th Dec, 2009 at 02:52:16pm
Check your mixture. If it's running lean it can cause running on. |
5th Dec, 2009 at 04:39:14pm
also timing too advanced and low grade fuel
5th Dec, 2009 at 10:10:51pm
Altinator back feeding through the ignition light circuit thereby powering the coil. Fit a diode! Own the day
6th Dec, 2009 at 02:38:09am
er..any pic?
On 5th Dec, 2009 metroturbo said:
Check your mixture. If it's running lean it can cause running on. http://www.minimonstermotorsport.blogspot.com/
6th Dec, 2009 at 02:38:39am
i've checked the mixture.everything is ok.
On 5th Dec, 2009 BENROSS said:
also timing too advanced and low grade fuel http://www.minimonstermotorsport.blogspot.com/
6th Dec, 2009 at 02:40:20am
i've checked the distributor timing.
On 5th Dec, 2009 Mr Joshua said:
Altinator back feeding through the ignition light circuit thereby powering the coil. Fit a diode! http://www.minimonstermotorsport.blogspot.com/
6th Dec, 2009 at 02:41:56am
how to put it eh?
6th Dec, 2009 at 02:43:08am
forgot something.
6th Dec, 2009 at 07:23:02am
If it only happens when hot, then it is hotspots in the cylinder head, not a backfeed to the coil. So it's either mixture, timing, grade of fuel or you need the anti-run on valve. Leyland/Rover opted for the anti-run on valve to avoid sorting all the other issues. Schrödinger's cat - so which one am I ??? |
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
6th Dec, 2009 at 09:10:22am
What grade of plugs are you running? |
6th Dec, 2009 at 09:15:34am
If your head is coked up it can also lead to hotspots that cause running on. I've had cars running on even with a working anti-run on valve. |
6th Dec, 2009 at 10:28:02am
Anyone know where I can get a Anti-run-on valve? i.e. what model the car is so I can try my local factor? I run a supercharger and I don't care the TB is on the wrong side.
6th Dec, 2009 at 10:35:33am
On 6th Dec, 2009 gr4h4m said:
Anyone know where I can get a Anti-run-on valve? i.e. what model the car is so I can try my local factor? The MG (N/A) Metro definately had them, well mine did. I think they may have been fitted to all Metro models with the high compression engine but not 100% sure. Schrödinger's cat - so which one am I ??? |
6th Dec, 2009 at 11:27:12am
I might have one throwing round Graham, I'll have a look when I get a minute. On 11th Feb, 2015 robert said:
6th Dec, 2009 at 11:52:39am
i'm using NGK BP6S
On 6th Dec, 2009 n.g.l. said:
What grade of plugs are you running? http://www.minimonstermotorsport.blogspot.com/
6th Dec, 2009 at 11:55:17am
can anyone show the pic of the anti-run on valve and where it is located? http://www.minimonstermotorsport.blogspot.com/
6th Dec, 2009 at 12:05:46pm
If you have, or can borrow, the Haynes (red) Metro manual it's on pages 4.12, 4.13 including a photo.
6th Dec, 2009 at 12:14:15pm
i didnt have the metro manual..
6th Dec, 2009 at 07:41:22pm
On 6th Dec, 2009 apbellamy said:
I might have one throwing round Graham, I'll have a look when I get a minute. I run a supercharger and I don't care the TB is on the wrong side.
203 Posts Member #: 1734 Senior Member Lancaster |
7th Dec, 2009 at 10:49:21am
I just used to stall the engine (drop the clutch) when mine ran on. As metroturbo says, sometimes it does it just when the head needs decoking. ie carbon still glowing causing engine to fire. |
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
7th Dec, 2009 at 08:46:35pm
Mine stopped running on (well, almost!) after I fitted a new radiator. The problem with the anti-run-on valve is when it leaks air and burns your valves...
Edited by h4887 on 7th Dec, 2009. Geoff |
11th Dec, 2009 at 03:03:37pm
Ah the full story.
On 6th Dec, 2009 Rod S said:
If it only happens when hot, then it is hotspots in the cylinder head, not a backfeed to the coil. So it's either mixture, timing, grade of fuel or you need the anti-run on valve. Leyland/Rover opted for the anti-run on valve to avoid sorting all the other issues. Own the day
36 Posts Member #: 4335 Member Hull / Scunthorpe |
14th Dec, 2009 at 04:55:19pm
Cooper carbs have them installed too (ARV) |
