Home > Technical Chat > Using Mini clocks on a metro turbo engine?
miniman03
Member #: 7642
Gillingham, kent
I have a Mg Metro Turbo 1.3 engine in my mini and have the original centre clocks. Can i still use the metro turbos clock wiring loom without buying metro turbo clocks?
cheers jay
You don't need to use the metro's wiring loom at all. Stick with the mini loom, clocks etc and get a normal boost gauge. Job done.
The Metro's ECU does a little bit of boost control. You can get a manual boost controller which sits in the sense pipe between the compressor and the actuator.
The only think you might need is the supply plug for the dizzy, but it's easy enough to join that into the mini's loom.
