| Home > Help Needed / General Tech Chat > Which stat?? | |||||||
![]() 323 Posts Member #: 41 Senior Member |
21st Oct, 2003 at 05:25:52pm
What thermostat do you guys run in your turbos? i have heard of some people running without a stat in. i need to order one so thought i would ask what would be best for a modded turbo, cheers! A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
291 Posts Member #: 48 Senior Member Leicester |
21st Oct, 2003 at 05:32:11pm
I run an 82o stat with no prob's
21st Oct, 2003 at 05:32:14pm
also, where would be the best place to get the 3 exhaust elbow studs from? turbo technics?? A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
21st Oct, 2003 at 05:34:37pm
i take it the idea of the higher temp stat is to allow the engine to warm up quicker, and vice versa A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
22nd Oct, 2003 at 01:31:23pm
I was just about to ask about elbow studs - i seem to have lost one ! |
22nd Oct, 2003 at 03:47:50pm
i need all 3!!! lol A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
22nd Oct, 2003 at 08:06:30pm
any good stainless stud will do. Go to any good hardware shop and get some stainless threaded rod On 15th May, 2009 TurboDave said:
22nd Oct, 2003 at 08:10:15pm
yeah im gonna do that jimster, there is a good nut and bolt shop near to me, just need to take the elbow with me as they are all different lengths. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
111 Posts Member #: 29 Advanced Member Croydon |
22nd Oct, 2003 at 10:38:34pm
Too many projects! |
23rd Oct, 2003 at 08:54:10am
It was bolts rather than studs in there originally. I'd use bolts personally - that way, you can remove the elbow with the turbo in situ... With studs, this will be impossible!
23rd Oct, 2003 at 09:13:08am
cheers dave i will do that, i was thinking about replacing the head/manifold studs with bolts too A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
23rd Oct, 2003 at 10:23:20am
I wouldn't bother with the manifold ones - there is so little clearance under the inlet - i think you'll struggle... A great idea on Nat Asp engines mind... On 17th Nov, 2014 Tom Fenton said:
23rd Oct, 2003 at 01:27:58pm
yes i had bolts on my 1275, as i found it easier to remove both manifolds by taking out the bolts, instead of sliding them over studs. will certainly use bolts for the elbow though A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
