Home > Help Needed / General Tech Chat > got a problem about my Duplex Timing Gear .
jom
Member #: 6003
i got a new Vernier Duplex Timing Gear . and i took two crank shims off to align both gear up . but when i put the chain back, i found a problem. the chain touch the two bolts behind the gear.*oh well*
the trick is to countersink the backplate and use countersunk allen (socket) head screws.
jom
Member #: 6003
ohh, looks like i know what 2 bolts for.. there are two bolts with the timing gears in the box. i was thinking about what the two bolts for
Mr Joshua
Member #: 1954
Luton Bedfordshire
*Punch* Read the instructions.
Own the day
c2_mad
Member #: 4215
hi guys, i know this is an old post but im just fitting my dupplex, and has encounterd a problem also. i can get the big sprocket on the cam, its tight but it goes on, last bit i might need to tap it in.
bu the sprocket that goes on the crank that is bloddy tight... will need to use a big hammer to get it in. is this normal? my stock one goes in fine. oh and if i put the sprocket the wrong way round i get get it in to a certain point.. has this ever happend to anyone?
am i missing something really obvious??
pleas help
remove the key with a screw driver and get some emery cloth on the crank and give it a good going over.
do the same to the inside of the cam gear too.
c2_mad
Member #: 4215
no emery cloth here, i dont even know where they would sell it here in portugal, would wet and dry say 600 be good enough mate?
yeah, that will be fine, you might need to go a bit coarser
c2_mad
Member #: 4215
ok mate.. will give 250 a go and then a bit of 400 or 600 to get it smooth..
thanks for the tip mate*wink*
We just used a small file (attached to Benross' hand) when we put the vans engine together.
Often it is just the corners of the keyway in the sprockets - a small burr gets raised when the keyway is broached - so a small file on those two corners often helps.
The other thing that can happen is the key itself moves in a rocking motion as the sprocket is being pushed on so the far end (the end you can't see) starts to rise out of the groove and hence makes things go tight.
bennyy
Member #: 9037
Doncaster, yorkshire
Suprisingly so did I, good old steve, I also used 400 grit on the crank as per benross' orders works a treat.
On 15th Mar, 2012 wil_h said:
