| Home > Technical Chat > Short compression height pistons | |||||||
7th Dec, 2009 at 12:09:12pm
Ok, bare with me on this one
7th Dec, 2009 at 12:15:05pm
You are right, mini pistons are top heavy,
7th Dec, 2009 at 12:58:44pm
To do the job REALLY properly, you need longer rods. Longer rods, and lower pistons are they way forward! On 13th Jul, 2012 Ben H said:
7th Dec, 2009 at 01:50:11pm
21251s sit really low, ive had a set in a decked blocked before. Altho there made from chocolate 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
7th Dec, 2009 at 01:54:45pm
I was looking at these in the short compression height, but as I''m not sure what the std compression height is its hard to call it.
7th Dec, 2009 at 02:03:28pm
std compression height is pretty much 1.5" so those arn't much shorter really. On 28th Aug, 2011 Kean said:
124 Posts Member #: 1126 Advanced Member peterborough |
12th Dec, 2009 at 08:02:21am
longer rods slows piston acceleration also, improves gas flow around tdc, such tiny improvements for massive costs though! |
12th Dec, 2009 at 08:25:09am
Just a thought, if the pistons are approx 2mm shorter? it would make them effectivly a 17cc dish? that could help out a lot if you trying to get lower comp on a big bore without doing to much to the head. |
12th Dec, 2009 at 10:10:43am
Ruins squish though, and maintaining squish is the current way of thinking On 26th Oct, 2004 TurboDave16v said:
