| Home > Help Needed / General Tech Chat > 850cc engine help/advice. | |||||||
![]() 380 Posts Member #: 1835 Senior Member Thame, oxfordshire |
8th Dec, 2009 at 10:33:36pm
Hello gents
On 23rd Aug, 2010 Nic said:
Turbophil had a butt plug made that seemed to be suitable. He may have finished with it now and have it kicking around spare |
9th Dec, 2009 at 08:06:20am
My 998 clubman ran much better with a HIF38 than it did with HS4. The maniflow exhausts are very good, the best IMHO On 11th Feb, 2015 robert said:
9th Dec, 2009 at 08:56:37am
I think your HS4 was goosed to be fair though Andy. HIF38's do flow better than HS4's however. If something is worth doing, it's worth doing half of. |
9th Dec, 2009 at 09:12:23am
On 9th Dec, 2009 minimadmotorman said:
HIF38's do flow better than HS4's however. Why is that? On 13th Jul, 2012 Ben H said:
9th Dec, 2009 at 09:46:12am
i thought size for size the only pro to the HIF is the fuel being under the jet rather to one side Yes i moved to the darkside |
9th Dec, 2009 at 09:52:16am
I have no hard evidence V. Just going on what I have read in the past, and personal experience of driving the same car equipped with both carbs. (not a conclusive test I know)
HIF38's do flow better than HS4's however. Why is that? If something is worth doing, it's worth doing half of. |
9th Dec, 2009 at 09:57:41am
I believe this is the article I read with reference to superior flow potential of HIF carbs.
9th Dec, 2009 at 10:21:39am
i would place a HIF carb on there,
9th Dec, 2009 at 10:25:04am
thanks everyone, i managed to track down a few topics on TMF too (even with their search function!!)
9th Dec, 2009 at 10:28:52am
thanks benross, i was thinking of contacting you with in relation to some head work, that will be the next move i think.
9th Dec, 2009 at 10:37:05am
in the Vizard book the flow of a HIF6 is 240 CFM vs 210 CFM for an HS6,
9th Dec, 2009 at 11:13:59am
I just cannot understand why. The internals are VERY similar if not identical. I'll have to measure.
9th Dec, 2009 at 11:20:33am
How often do you have to trouble shoot a HIF carb let alone a HS carb to justify choosing the HS carb over the HIF purely for that reason? On 26th Oct, 2004 TurboDave16v said:
9th Dec, 2009 at 11:52:47am
Well i havent looked at an HS for many years, but from memory the hif has a much more radiused inlet to it, If the flows were taken with no form of ram pipe this could acount for the difference.Also I think the casting on the HIF was a bit better ie less flashing marks, so tickling out an HS with a dremel could even things up too.
I just cannot understand why. The internals are VERY similar if not identical. I'll have to measure. I love HS carbs compared to HIFs. The external float is soo much for troubleshooting etc. On 28th Aug, 2011 Kean said:
