Home > Help Needed / General Tech Chat > the turbo dont work good
supermini
Member #: 187
hi
I'm having problems with my turbo mini please help
i have a complete MGTurbo engine just fit in my mini, it has been completely repaired but i cant make it work properly.
in the road when the turbo shoud make its job i feel engine just dies ir seems the turbo dont work but it is new!
anyone can help me ?
Kean
Member #: 341
aka T2clubby
South Staffs
if you mean that when the turbo kicks in the engine is dying.... which I think you do..
sounds like you have either a leak or an open pipe on the carb.. check the balance pipe that goes from the left of the carb to the front top of the carb
do a search on this site for boost problems
hth
Gibbo
Member #: 34
Sounds like a fueling problem.
Check the fuel pressure is set to 4psi at idle.
Also check that the plenum gasket has all the holes in it. Some don't and then the float chamber doesn't pressurise.
And make sure your fuel pressure reg is connected correctly!
You haven't given much information, so read a few old posts so you get an idea what also to check. Then post back up your findings.
Check that the float chamber venting pipe is blocked.
Phil. *smiley*
minimark
Member #: 19
newcastle
where abouts are someone may be close enough to look at it for you
