| Home > Help Needed / General Tech Chat > Flywheel Bolt Lock Tab | |||||||
10th Dec, 2009 at 07:57:11am
Pre-verto flywheel bolt lock tab - Is it generally thought to use it or not? If not should a dab of threadlock be used?
10th Dec, 2009 at 08:32:16am
I always use one. But I agree, a PITA to keepin place. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
10th Dec, 2009 at 08:42:35am
I seem to remember old ones stayed in place because they were made of something called metal, not like the new ones that are made of cheese. http://www.twin-turbo.co.uk
10th Dec, 2009 at 09:31:35am
Soft spready cheese at that. |
10th Dec, 2009 at 09:50:19am
I gave up using them a long time ago, use some 270 locktite and torque to 120Ft/lb, tap the flywheel all around the outer edge with a hammer and a block of wood then re torque job done On 17th Feb, 2009 Rob H said:
10th Dec, 2009 at 10:12:47am
locktite here too! On 28th Aug, 2011 Kean said:
10th Dec, 2009 at 12:04:27pm
Loctite!
10th Dec, 2009 at 01:31:13pm
yes, but i'm a bodger and use an old bolt with a slit cut in it, and a load of solvent. On 28th Aug, 2011 Kean said:
1425 Posts Member #: 690 Post Whore Norfolk |
10th Dec, 2009 at 05:30:40pm
As above the locktabs are made of cheese and not worth using.
If Carling made Mini engines
10th Dec, 2009 at 05:39:47pm
Also I do the TD method of putting the flywheel on hot. On 28th Aug, 2011 Kean said:
