Home > Wanted > nuts needed for rear trunion pins
turboandy
Photobucket" alt="User Avatar" width="100" height="100">
Member #: 1735
morton, lincolnshire
hi guys desperatly need the 2 nuts for the rear subframe trunion pins. (the big pins that hold the front of the rear subframe) mini sport have sent the wrong one to me twice now.
i think they are 11/16 UNF need them really urgent please can someone help lol:)
advantage998
Member #: 1840
Kings Lynn, Norfolk
They should just be bog standard 7/16th UNF nylocs, the majority of fasteners suppliers should stock them.
turboandy
Member #: 1735
hi the 7/16th that i have recieved from mini sport fit the smaller trunion pins that go through the boot floor. im in need of the bigger nuts for the large trunion pins at the front of the subframe, thanks anyway advantage998
t3gav
Member #: 229
Gavin@minispares.com
kent
Yep should be 7/16th, the rear pin also takes this size!
Anton
Member #: 764
Staffordshire
The nuts are usualy captive into the body, has someone fitted metric studs by any chance?
These are 5/16UNF.
t3gav
Member #: 229
kent
He said trunnion pins not the bolts that actually go through the floor, confused me had to read it 3 times lol.
There are four bolts through the boot floor, they are 5/16.
Pins??
Nah, I don't get this...
Anton
Member #: 764
Staffordshire
Ahh, yes I see now, I thought they were the same as th rears.
t3gav
Member #: 229
kent
The bit the rear bushes sit on as part of the rear subframe :)
I think that the problem is that you are ordering nuts based on the A/F dimension rather than the thread diameter.
You need 7/16 UNF thread with an 11/16 A/F hexagon nyloc nut.
The big shiney bits in this
http://www.minispares.com/Product.aspx?ty=...=0&tc=1#submenu
or rather the nuts that go on the end of them I presume.
In which case mine are also 7/16" UNF.
The head of the nut is 11/16" A/F but the thread is 7/16" UNF.
EDIT - too slow, Paul just said the same thing.....
Edited by Rod S on 11th Dec, 2009.
Front ball joint nuts and spring washers are the same I believe?
t3gav
Member #: 229
kent
http://www.minispares.com/Product.aspx?ty=...36580&title=NUT NYLOC 7/16UNF
turboandy
Member #: 1735
hi thanks for all the help gavin @ mini spares has got the ones i need, i will get them ordered now. ive found out the ones that mini sport sent out twice wrong are 5/16 i think it may have been the way i was explaining what i needed thank though everybody that posted
