| Home > Wanted > manifold take off thingy ha | |||||||
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
10th Dec, 2009 at 11:39:40pm
little take off bit for the top of the manifold where i put my dumpvalve or boost gauge On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
487 Posts Member #: 1495 Senior Member |
11th Dec, 2009 at 10:23:11am
plenum? |
11th Dec, 2009 at 10:30:52am
Like this? http://minispares.com/Product.aspx?ty=pb&p...&title=MANIFOLD ADAPTOR 1.75 |
13th Dec, 2009 at 12:02:51am
nope the bit that screws inot the top of the manfold. where the vacum goesfrom boost or dump valve On 27th Apr, 2010 Rick.SPI said:
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
13th Dec, 2009 at 09:32:30am
i also need one of these! any luck jamz? |
13th Dec, 2009 at 11:56:25am
Jamz, it is a large bolt that goes into the top middle of the manifold, correct?..
Edited by giallofly on 13th Dec, 2009. On 21st Jan, 2011 fastcarl said:
13th Dec, 2009 at 12:27:11pm
13th Dec, 2009 at 01:33:48pm
I will take a look for it, I have a MOOSIVE box of nuts/bolts/bits/bobs.. Failing that I have a spare Challenge carb/manifold in stock...
13th Dec, 2009 at 02:21:33pm
yer no rush at all. how much for the carb and manifold? i could do with a spare On 27th Apr, 2010 Rick.SPI said:
13th Dec, 2009 at 03:58:42pm
No it my spare.... I was saying I am sure that has one fitted that you could have.
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
14th Dec, 2009 at 06:53:18pm
Are you running with or without the servo? I've got one for without a servo but I need one with a servo if you get what I mean? On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
14th Dec, 2009 at 09:45:10pm
15th Dec, 2009 at 09:48:55am
I use the standard banjo bolt for the servo and that manfold adaptor for the dump valve. |
15th Dec, 2009 at 11:31:15pm
On 14th Dec, 2009 jamz said:
no servo. is there a difference? I got one a couple of months ago that is just a bolt that fits in the hole with a small boost take off on it. The other one is a banjo bolt type for the servo, with a bigger boost take off on it. On 25th Sep, 2009 mini13 said:
