| Home > Help Needed / General Tech Chat > rocker ratio recommendation for phase 2 cam | |||||||
263 Posts Member #: 115 Senior Member Austria, near Vienna |
28th Dec, 2004 at 08:41:51pm
Hi there! Bimmer Twinky headed and turboed A-Series:
28th Dec, 2004 at 08:57:01pm
Mine is timed in at 109 degrees - last year it was 108 degrees. Last year I ran 1.25 and was reasonably happy with the drivability, this year it's definately lost low down drivability and smoothness after fitting the 1.5 rockers... On 17th Nov, 2014 Tom Fenton said:
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
28th Dec, 2004 at 09:03:44pm
I plotted some graphs (because I was bored) and looked at comparing going up an exhaust valve size 29>32 and that gave +10% more area, the 1.5 rockers give a 15% increase. But, it does have a greater area under both curves. (more area to blow across).
Bugger off, I'm getting there. |
28th Dec, 2004 at 09:24:50pm
I am using a 36/31 head at the moment. Dave, did you gain some power at the top end with the 1,5 rockers? Or was it a "lose bottom end and gain nothing at the top end" game?... Bimmer Twinky headed and turboed A-Series:
28th Dec, 2004 at 10:28:42pm
Well the car is definately quicker, but I'd also change exhaust size aswell - I'd been using a 1 3/4" downpipe, but switched to a 2" downpipe at the same time... Basically, I feel i didn't see enough of a change to warrant the need for the 1.5 rockers. I'll be switching back to 1.25 cooper S rockers next time the head is lifted. On 17th Nov, 2014 Tom Fenton said:
28th Dec, 2004 at 10:40:17pm
I haven't got any S-Rockers yet. I had some forged A30 ones but I think they were weak as cheese :) I was debating running my sintered ones just to see what I thought, but I think I will go for a set of S ones and forget the 1.5's.
29th Dec, 2004 at 06:38:14pm
i wouls stick to 1.25 or 1.3 roller tips as 1.5 roller tips do put a ;lot of stress onto the cam lobes and shag them up after a year. always looking for them bigger bunches of bannanas |
29th Dec, 2004 at 08:38:02pm
Do many 1,5 rockers user on this board destroy camshafts? Never had cam problems with longer duration cams and 1,5 rockers. The problems started with my 274i cam and 1,5 rockers on the inlet lobes. (only 248? inlet duration) Bimmer Twinky headed and turboed A-Series:
29th Dec, 2004 at 10:05:16pm
Personally - I'd be speaking to Kent about the cam... What do the followers look like?
30th Dec, 2004 at 07:11:32am
I will speak with them! The followers on the inlet lobes are pitted, the exhaust followers look like new! Bimmer Twinky headed and turboed A-Series:
30th Dec, 2004 at 09:20:39am
my 276 which i took out of 1275 was the same inlets shagged but exhausts were ok.
421 Posts Member #: 245 Senior Member |
31st Dec, 2004 at 07:11:59pm
1.3s with phase 2 cam is the way i have gone with my re-build, Edited by sauber 200 on 31st Dec, 2004. |
31st Dec, 2004 at 09:33:29pm
I thought pitting was a result of shit in the oil. Funny, 2 of my inlets were pitted and the rest fine. Apparently, the cam follower problem is only with the transverse type engines. They last for ever on the inline stuff. Even with silly ramp rates.
1st Jan, 2005 at 11:21:10am
Do you think the gears throw particles up, which will find their way between follower and cam and destroy it? What speaks against this theory is, that only the inlet lobes are affected. If debris is the cause all lobes should have this problem?! Will contact Kent and see what they are telling! Bimmer Twinky headed and turboed A-Series:
