Home > Help Needed / General Tech Chat > Petrol gauge
Richard Waller
Member #: 7334
Maldon,Essex
Hi, wonder if anyone could help me here. My minis fuel gauge always reads 2/3's full! I've replaced the sender, and the dial twice. Also it had complete new wiring in it only a year ago. The car was an Spi, but now running HIF44 with 'charger. The tank was changed at the time of convertion to a pre injection one so I didn't have the fuel pump inside it.
Any ideas?
Richard
Low, fast and aggressive looking......
Doesn't imitate something it's not!!!
Now a "Super Bullet"
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
Does "always" include when the ignition is off? Or does it drop to zero with the ign off?
Have you tried just 2 direct wires from the sender to the gauge, see what that does?
Richard Waller
Member #: 7334
Maldon,Essex
Yeah it turns off when not in use. Haven't tried two direct wires though.
advantage998
Member #: 1840
Kings Lynn, Norfolk
A faulty voltage stabiliser on the dials maybe??
Richard Waller
Member #: 7334
Maldon,Essex
But I've used to different dials! Of course that could mean both out! Just wondered if anyone has had this before and new a fix lol!
Star Mag
Member #: 375
Leicestershire
I had this problem with mine when I had the spi tank. Thats if you have one?
Richard Waller
Member #: 7334
Maldon,Essex
Mine was the spi tank, then chaned to a pre injection one. I had a spi sender in that, and that went from full to 1/2 full then just dropped completly! Changed the sender last week hoping it was readin wrong because of that, but still gettin incorrect readings.
fuel gauges are funny fuckers Rich,
the voltage stabaliser can cause issues between old an new types, you need to check tht you have the same voltage to the gauge/sender running and not running.
If you get stuck i can pop over and take a looksie, I need to drop in Andy's RTS bits anyway.
Richard Waller
Member #: 7334
Maldon,Essex
That would b great, have to sort out a time/ date!
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
did you fix it???
i have same problem, when tank is full it shows only 2/3 on it :(
Nothing special!
