Home > Technical Chat > turbo
turboestate
Member #: 362
durham area
hi again just to let you know of some changes to the car, ive changed the turbo from the garrett t3-t04e back to a standard t3 as it was producing to much air for the engine, after change the car picks up like sh*t of a shovel still only on 5PSI boost, also just fitted lambder sensor and air/fuel ratio meter al seems well so ill be turning up the boost see what hapens?
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
nice, anymore pictures to show of your little beast?
clubman_dan
Member #: 142
Winchester
cool, am i the only one who voted? *tongue* lol
b16_b
Member #: 429
newcastle upon tyne
looks mint this! seen it at minimania04 best car at show!
turboestate
Member #: 362
durham area
cheers for that lads im hopeing to post some more pics sone goes well after mods!*smiley*
______
/___|_____
_ (@)___(@)
colas
Member #: 102
Pennsylvania USA
Hey
What sort of Lambda setup are you using. I want to fit one to mine but Im unsure what Sensor to buy.
Thanks
turboestate
Member #: 362
durham area
HI THERE IVE USED A LAMBDER SENSOR FROM A NISSAN ITS A 4 WIRE TYPE 2 WIRES ARE FOR A HEATER SO IT READS FROM IDEL, IN CONJUNCTION WITH A LD-30 METER WHICH I PURCHASED FROM EBAY. ACORDING TO THE PAPER WORK WHICH CAME WITH THE METER ANY SENSOR WILL DO FROM 1 WIRE UP TO 4 AS IT ONLY USES THE SIGNAL WIRE HOPE THIS HELPS.
______
/___|_____
_ (@)___(@)
colas
Member #: 102
Pennsylvania USA
Ok Thanks
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
basically a narrow band sensor :)
alex
AlexF
turboestate
Member #: 362
durham area
yes 0-1V depending on oxygen content.
______
/___|_____
_ (@)___(@)
