Home > Help Needed / General Tech Chat > Heat Shield Material
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Made quite a few heat shields in the past from stainless steel, which problably retains the heat longer.
Planning an improved version with reflective heat blanket on the outside of it.
Any thoughts on the main part being aluminium?
Pros & cons?
On 19th Jan, 2010 wil_h said:
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
You want as high a heat capacity as possible so that it takes more units of energy to heat a part to a given temperature. Aluminium has a much lower heat capacity than stainless. Also, the mass of the aluminium shield would be less than equivalent stainless one.
At least I think that's how it works
On 30th Apr, 2010 Rod S said:
Gary's description is best
wintersurferuk
Member #: 2208
i found this, such a cheep good idea not sure if it helps ya, im going to give it a go soon.
http://forums.hybridz.org/showthread.php?p=854993
after reading toms thread about heat wrap im not going for a turbo sock.
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
LOL
Right doggie finish that dinnner quick!!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
lol
