| Home > General Chat > OT: LIF Hard Drive Connector | |||||||
17th Dec, 2009 at 01:45:41am
My beloved Sony NW-HD5 mp3 player is dead. It uses a Toshiba MK2006GAL 1.8" HDD which no longer reads. Since I had no choice but to use Sonys proprietary sotware to install music on it, I am now in the shit. And it's in ATRAC3 format to make it even more awkward. It seemed like a good idea at the time, but so did laser discs. I dropped it into a local computer place who said they might be able to take the data off if I can get a LIF connector. They are having trouble finding one though. I don't fancy having to reload 400 albums onto a new MP3 (as it would take years and a lot of them are now lost or scratched) so I really need this to work. Also, I'm an annoying arse with punctuation and formatting of artist, album and song titles which would make the task infinately more time consuming.
Gary's description is best |
17th Dec, 2009 at 07:30:01am
Are you sure it's LIF and not ZIF on the HDD.
17th Dec, 2009 at 09:18:48am
Get an iPhone and be done with it :-p On 17th Feb, 2009 Rob H said:
17th Dec, 2009 at 09:18:51am
I have nothing more to add to this, Edited by PaulH on 17th Dec, 2009. On 17th Feb, 2009 Rob H said:
17th Dec, 2009 at 10:49:37am
Paul, you're a cock! haha
17th Dec, 2009 at 11:05:00am
A quick search says they are essentially the same, just the cable on the LIF is slightly thicker because it's only Low Insertion Force rather than Zero Insertion Force.
17th Dec, 2009 at 11:20:04am
Thanks Rod, that sounds like exactly what I need to hear. I will read that link now and hopefully get the computer place to make some progress. I may even look into sorting it myself if they are reluctant to do anything On 12th Nov, 2009 Paul S said:
17th Dec, 2009 at 11:47:55am
But if the ZIF cable is half the thickness then maybe it won't connect properly or be held properly by the clamp?
17th Dec, 2009 at 12:20:06pm
Yes, graemec. It is the cable I am looking for. You could be right about it not cennecting properly. Would it be worth a go anyway? On 12th Nov, 2009 Paul S said:
17th Dec, 2009 at 12:27:11pm
Possible but if I was doing it and it seemed loose I'd try something like a thin strip of paper between the clamp and the cable. I've dismantled and re-assembled several of these connectors on thing like PlayStations, set-top boxes etc. where they use them for cables between boards and so long as the clamp pushes the silvered side of the ribbon cable down onto the contacts (once the cable is located in the slot) they allways worked again. But I never knew there were two different cable thicknesses until today...... Schrödinger's cat - so which one am I ??? |
17th Dec, 2009 at 12:49:49pm
Rod, as you have experience with doing similar I think that would give me the confidence to try it. I think I'll be ordering a cable off ebay tonight.
17th Dec, 2009 at 01:27:21pm
It's got to be worth a try BUT, check the one I linked on ebay first, the photo doesn't show the short length of ribbon cable you need.
17th Dec, 2009 at 01:35:19pm
Or try this
22nd Dec, 2009 at 05:58:06pm
OK, a little progress made on this (ish). The computer place had hard drive enclosures in stock (for ZIF connectors). The ribbon cable is actually wider than the connector. The one in the post above also looks wider. Can I simply cut the ribbon to size?
22nd Dec, 2009 at 06:07:37pm
Count the exposed (silvered) wires on the cable and the contacts in the connector housing.
22nd Dec, 2009 at 06:16:59pm
That makes sense Rod, thanks. I'll get the microscope out :) .
23rd Dec, 2009 at 02:10:19am
I think I have now found a solution:
23rd Dec, 2009 at 07:50:35am
If the ZIF/LIF cable connector just plugs into the back of the drive through a normal (but small) male/female IDE pin arrangement it seems to defeat the point of having the ribbon cable in the first place, unless they wanted to have the option of either type of drive.
