| Home > General Chat > Which DV | |||||||
![]() 323 Posts Member #: 41 Senior Member |
22nd Oct, 2003 at 03:59:05pm
what type of dump valve do people recommend? im sure i have read somewhere that a piston type is not the correct one to use for the a series but i have seen several in action and work well. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
111 Posts Member #: 29 Advanced Member Croydon |
22nd Oct, 2003 at 04:48:22pm
Too many projects! |
22nd Oct, 2003 at 07:58:45pm
haha, that doesnt suprise me in the least that avonbar would make up something like that, i had the same happen to me over the cylinder heads that they supply which come from longman..except longman told me they arent supplying avonbar with their heads A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
