Home > Help Needed / General Tech Chat > Metro Master Cylinder fitting size
One of the last things stopping us getting the van driving again is the clutch.
Everything is in, but I'm struggling to connect the master and slave cylinders.
We have a mini slave cylinder with a 3/8 NPT thread in it.
The master cylinder thread is bigger, but I don't know what size. I tried an 11/16 NPT fitting, but it was slack. An m12 bolt will turn in a couple of turns, but binds so I'd thought 1/2" npt. So I bought a 1/2" npt fitting and it was huge.
Now I'm just confused. Does anybody know what size it is?
If it comes to it I will fit a mini master cylinder, but I'd rather use the 'orginal' metro style one and just but a fitting in to convert the thread down to 3/8 NPT and use the nice shiney braieded hose...
It's where the purple bung is in this pic:
is it not metric?
tadge44
Member #: 2500
Buckinghamshire
I,m confused (easily done !) you say a 1/2 inch NPTnpt is bigger than 11/16 NPT ?
Im agree with Graham, this must be metric.
I think its M12, but with a finer pitch than the M12 bolt you tried to screw in.
Make that 9/16. It was a bit early...
I've had a look at the orginal fitting. it looks to be slightly tapered...
As per Joe,
The yellow band master cylinder I'm installing on the Mini is metric on both threads (M10 and M12) but the M12 is X 1.00 pitch.
So metric fine but not even the usual metric fine...
For M12,
Standard ISO (coarse) is X 1.75
Usual fine is X 1.25 but ISO 724 allows for X 1.00 as well.
so it's either a custom braided hose or the mini master cylinder then. I'm not sure if the mini one will fit - I think it may hit the servo.
I guess I need to find a hose place near me and get one made up...
get a hose made with a banjo at each end, then you can just swap the bolt and washers?
Or alternativly... If I got a correct M12 male break pipe fitting, put it on a short length of brake pipe with a 3/8 NPT fitting on the other end I could use the standard mini braided hose.
Would the flexibility of the copper pipe cause and problems with clutch operation??
Yes, the conversion kit quoted in my master cylinder box was a genuine rover pair of pipes to convert the metric (yellow band) master cylinder to plumb into a UNF (black band) installation.
I just bought the new metric unions from DSN when I called in to buy the master cylinder.
(except it's 3/8 UNF, NOT NPT at the other end......)
I think I'll get a custom braided hose as Joe says. If I take the orginal fitting from the old master cylinder they should be able to match it up...
Thanks for the help.
Just been filing away my invoices....
If you want to use a new union and it is the same as the Mini brake one (M12 X 1.0) which is 99% likely, the DSN part number is BRK3157.
60p + VAT when I bought it last month.
But any good auto factor or hose fabricator should have one.
probably a daft question, but would it be possible/advisable to drill and tap the old union to take the 3/8 fitting??
If you mean drill the centre out of the old M12 union and tap it 3/8, it is theoretically possible.
With the very fine X 1.0 thread, the thread root diameter of the fitting is ~10.8mm and a 3/8" UNF thread tooth diameter is ~9.6mm so you would have a 0.6mm thick sleeve carrying the load.
Take manufacturing tolerances of the M12 thread and the quality of a hand tapped 3/8 thread it could be as little as a 0.4mm thick sleeve.
Mathematically a 0.4mm sleeve would easily carry the load but in practice it would probably shear when you were tightening it.
I would NEVER consider such a practice for a brake fitting but as it's only the clutch......
Edited by Rod S on 20th Dec, 2009.
My fists are made of ham. I'll buy a hose...
Well. I have a nice new shiney braided hose with a 3/8 UNF banjo fitting on one end and M12x1mm banjo fitting on the other end. It's all bolted in and looking lovely, but... the M12 banjo bolt is 6mm too long.... :$
Of I go in search of a space or a shorter bolt....
Hacksaw!
On 22nd Dec, 2009 mini13 said:
Hacksaw!
Dremel perhaps. I tend to destroy the thread when I use a hack saw to chop down bolts....
or maybe...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=330388774096
Or just 3 or 4 copper washers instead of one....
But surely if the hose supplier can do the M12 X 1.0 banjo bolt, they must have it in different lengths ???
I had thought about the washers, but wasn't sure if it would seal well enough - 6mm will be closer to 5 ot 6 washers.
I'll give them a call tomorrow, they did seem well stocked.
andy ,the washers would work .
metroturbo
Member #: 989
North Yorkshire
Stick a bolt on first, then chop it down. Remove the bolt, and it tidies the thread as it screws off.
evolotion
Member #: 83
Glasgow, Scotland
m12x1mm bolts arnt particulry common though, if it were for a customers car i'd cut the bolt down and use a 1.0mm pitch thread file. if it were my car id just throw in a few extra washers.
Denis O'Brien.
tadge44
Member #: 2500
Buckinghamshire
Cut it down, Andy, you know it will look better and always aggravate you if you stick a load of washers in there.
If you mess it up you can always get another, plus, if you never practice, how will you get better at it !!
