| Home > Help Needed / General Tech Chat > alternator fitting issues | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
19th Dec, 2009 at 04:06:16pm
why isnt anything ever straight forward?!
19th Dec, 2009 at 04:14:52pm
first off,
19th Dec, 2009 at 04:43:09pm
put washers between the alternators bottom bolt and space the adjusting bracket away from the alternator to wards the engine plate,
Yes i moved to the darkside |
19th Dec, 2009 at 05:37:29pm
Is that adjustment bolt the proper double ended pillar bolt? Can't make it out from the picture. |
19th Dec, 2009 at 05:48:31pm
Is that the correct alternator? Looks odd to me. Doesn't seem to be sitting straight.
19th Dec, 2009 at 06:00:06pm
I got some washers with my crank trigger bracket, so it can be spaced away slightly. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
19th Dec, 2009 at 06:22:28pm
Problem 1 solved, managed to crack off the pulley bolt and put in the spacer off the old alternator so the belt is straight and true.
21st Dec, 2009 at 09:40:59am
This is the correct bolt:http://www.minispares.com/Product.aspx?ty=pb&pid=34981&title=ALTERNATOR BRKT PILLAR(2A...
21st Dec, 2009 at 02:30:20pm
Thanks for the link to the bolt, I dont think I've ever seen one of those on all the mini's / engines I've had!
Edited by Simon on 21st Dec, 2009. |
