Home > Technical Chat > 160 bhp spec?
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
ive been hunting and researching for a while now so here goes.
im aiming for 160 bhp but 170 would be nice , im also on a budget so i cant really aim money at the engine bay with a big cannon.
my spec so far is this-
1275 std turbo pistons
oil spray jets
dry decked block, main straped , 11 stud.
12psi from a t25
mg, or avonbar phase 2 or phase 3 cam?
vernier belt drive
smart car intercooler with fan and an audi a3 intercooler both with water spray jets fitted
mg spec flowed and polished stg3 ish head giving 8.2:1 CR
being run by su carb with an avonbar 12psi needle and megajolt jr lite v4 from autosport labs
i know the pistons are a limiting factor but from research they will take that 12psi reasonably, and i dont want to melt expensive pistons if it goes tits up.
your opinions and ideas would be appreciated gentlemen...and ladies *happy*
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
I think 12psi for 160-170bhp is maybe a tad optermistic. A couple more may be needed.
Also I'd advise getting the fuelling set on a rolling road rather than relining on the Avonbar needle.
And don't bother with the P3 cam.
If you are on a budget I wouldn't bother with the oil jets. Also just wondering why 2 intercoolers instead of 1?
As for a cam MG or ph2 would be my choice. I hear the MG will help spool up the turbo a little earlier than the ph2 and will probably be cheaper (apbellamy may have one for sale as I believe he is getting a new cam for his build).
Again dry decking is a nice to have and not strictly necessary if you are on a budget.
Same with the belt drive unless you already have it stick with a duplex chain.
Also to re-iterate wil_h I reckon you will need some more boost to make 160bhp. We have a similar spec engine in the van and we are hoping for about 140-150bhp at about 14psi. Aparrently people have ran std turbo pistons at upto 18psi without problems.
We're using a T3 so the required boost to make the power might be different.
Yes, I will probably have an n/a MG Metro cam for sale after crimbo. All depends what Santa brings lol.
MONSTER HEDGEHOG
Member #: 4340
im going to set the fueling up with a wideband gauge first and then optimise it on the rollers, i was thinking that the avonbar needle would be a good starting point.
the oil jets and drydecking are free as its just metal and time.
im going by the idea of two intercoolers being better than one, just to make sure the charge temps as cool as i can get it.
i allready have the MG cam and a few spare, but i didbt realize it was actually better than the p2. why isnt the p3 cam anygood?
ive allso already got the belt drive setup as a cheap ebay job.
if the pistons will take 18psi then il go with 16ish as a safe mark
carl
Star Mag
Member #: 375
Leicestershire
I would start with a standard needle and profile it yourself the Avonbar ones I have had have been hit and miss!
Forget dry deck and belt drive, put that money towards some good pistons
Paul
cam wise, the Phase 3 is a proper race cam, it only comes into its own if you keep the revs high, its just not suited to the road.
Ph2 produces the goods but looses drivabillity over something like an MG cam.
Two intercoolers will be a PITA to plumb, I think it will be better to go for one big cooler.
nuukuus
Member #: 6857
Lieto / Finland
1 Big is better for sure but....
For exsample my engine bay, there is no room for one big cooler.
I'm thinking to put 2 cooler also. But then you must be sure that the second cooler is certainly cooler than the first.
Jani
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
You dont need to go so wild on a budget build!
Better pistons
good head
duplex cam driving a 255ish cam
and have fun :)
AlexF
MarkGTT
Member #: 1194
Shropshire.
as above,
mine is 'basically'..
1380
omega pistons
med fi head
avonbar ph2 cam
straight cut drops and box
xpin dif
big intercooler
megajolt
18psi
170 bhp :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
remmeber of course your gearbox needs to be good - std helicals on 170 in my glittery one munched itself very quickly more than one hehehe
AlexF
Alex was that with SC Drops or not?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
yes just the drops were SC
AlexF
MONSTER HEDGEHOG
Member #: 4340
the two intercoolers are because i dont really have the money for one huge one, and i also allready have the 2 intercoolers and they cost me nothing.
the dry decking is a small improvement over the std setup in my mind and although its not relly reccesary its worth having as it cost almost nothing to do and i recon should give me a slightly safer engine
for now ive got a jack knight rebuilt box with a rebuild 4 pin to use, but im just going to runn the engine in with this carefully and then get it on the rollers to see what i can get out of the engine.
the t25 ive got to use is costing me 40 quid befor i sell the t3 so should be good value for money, the one thing i hated about the t3 was the......... LAG..... so if the t25 gives me slightly less lag with similar power potential then im a happy man *happy*
carl
you can get a cossie cooler for about £20...
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Never seen a twin IC setup....all that pipework must be the same length as a humans intestine by the time you've finished!
On 19th Jan, 2010 wil_h said:
MONSTER HEDGEHOG
Member #: 4340
if you mean the 2wd one with the 45degree pipe at the top then ive allready got one of those as well *happy*
compared with the other two its smaller and thiner, i recon i can get the two coolers very close to each other with a minimal of piping, but il see how it pans out on the car.
carl
mine is basically ,
1310cc
home ported head
8.5:1 cr
gt17 turbo
omega cast pistons
stock block ,crank ,rods
not balanced
no centre main strap
helical drops
4 pin diff
straight cut clubman gearset .
small intercooler
verto clutch
mjlt
168 bhp at 6350 and 6950 rpm
12psi boost .
(all data at rr shootout )
Edited by robert on 23rd Dec, 2009.
You always piss up my calculations Robert. I wonder if the lower losses of the large turbine affect it?
MarkGTT
Member #: 1194
Shropshire.
i need a GT17.
Me 2!
I'd ditch the 2 IC setup and belt drive. Sell one of the IC's and put your money towards megajolt.
IIRC I made 150bhp at 8/10psi with a slipping clutch. So could be doable on 12psi with a higher CR. If your running 8.2:1 I think you'll need some more boost!
robert what cam are you using and the CR your running ?
impressive!
Its one of Roberts jiggery pokery magic cams. *wink*
