| Home > Help Needed / General Tech Chat > PLEASE HELP dizzy wiring colours? | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
24th Dec, 2009 at 12:28:05pm
Im stumped can anyone help? i have built my first new engine and im ready to wire the coil etc etc but i am having troublea. I have read up on here, haynes etc but all the colours for the dizzy described are different to what i have!
24th Dec, 2009 at 12:43:27pm
The dizzy part number is vissible in the first pick, near the dizzy clamp. post that up.
24th Dec, 2009 at 12:56:12pm
number--- 41632e59dm4>3883.
24th Dec, 2009 at 01:08:14pm
must be a really early metro turbo engine you have. before the ellectronic stuff. pop the cap off and have a look where the wires run to. if it just has a condensor and points then you can follow the wires back and wire as a normal points dizzy.
24th Dec, 2009 at 01:13:48pm
dont think so, pretty sure its electronic as there is no condensor! im thinking maybe something has been changed on the dizzy in the past? |
24th Dec, 2009 at 01:17:16pm
pop the cap of and put a pic up On 11th Feb, 2015 robert said:
24th Dec, 2009 at 01:18:01pm
That is a Mk1 turbo dizzy that uses a seperate ignition module. As opposed to the later type that has the module mounted on the side of the dizzy itself.
24th Dec, 2009 at 01:40:13pm
pic with the cap off.
24th Dec, 2009 at 01:44:31pm
left pic being the first dizzy
24th Dec, 2009 at 01:47:15pm
As TOm says, the first dizzy needs the external module.
24th Dec, 2009 at 01:51:09pm
ok great thanks is it worth buying the module or just buying the newer dizzy?.
24th Dec, 2009 at 01:54:22pm
Your problem is getting hold of the module.
24th Dec, 2009 at 02:26:32pm
ok thanks |
3rd Jan, 2010 at 12:33:53pm
Right more problems! i now have bought another dizzy off ebay which is ment to be a turbo one aswell but i am unsure. The plug on the box on the side of the dizzy has three pin connections and from what i have read on here there should only be two? anyone know anymore on this?. |
![]() 69 Posts Member #: 7124 Advanced Member emsworth somewere near portsmouth |
3rd Jan, 2010 at 12:54:58pm
on my old dizzy it had the 3 pin plug and i changed my module for a 2 pin one with then i put 2 spade connectors on then went to my coil |
3rd Jan, 2010 at 01:17:08pm
Three pin plug/socket were the later modules - but only two of the pins are used as the way they are wired up for the Metro (so mini) coil is the same.
3rd Jan, 2010 at 01:23:27pm
ok cheers chaps
3rd Jan, 2010 at 01:26:06pm
We have the 3 pin wire on the metro van, I can look to see which wires are which if you like. On 11th Feb, 2015 robert said:
3rd Jan, 2010 at 01:30:16pm
nice one that would be great!.
3rd Jan, 2010 at 01:50:39pm
With the dizzy fitted and the connector at roughly 2 o'clock. The top connector of the 3 (white wire) goes to the positive on the coil and the bottom (white/black wire) goes to the negative On 11th Feb, 2015 robert said:
3rd Jan, 2010 at 01:57:46pm
Great cheers for that legend!. |
3rd Jan, 2010 at 02:00:21pm
