Home > General Chat > proposed engine spec
Adam_R
Member #: 1938
near Dundee
ok so ive been planning my spec for a while now and have came up with this:
head:
std chambers (21.4)
basic home porting
bronze guides
std valves
Block:
bored 1293
mg metro cam
new vandervell cam bearings
omega 18cc forged pistons
crank:
std crank (ground if required)
new vandervell bearings
Gearbox:
contral oil pickup
minispares cross pin diff
minispares s/c clubman gearset
minispares s/c drop gears
rebuilt using comp baulk rings
ultralite flywheel
new clutch (suggestions please)
metro turbo manifolds
T3 turbo (unless i can get a gt17)
megajolt
ive worked it our to be roughly 8-7-1 c/r
if theres anything else i should be thinking of getting or indeed even changing please tell me
all opinions welcome
edit: oops
Edited by Adam_R on 27th Dec, 2009.
You'd probably be better of putting your guides in your head. lol
Advantage
Member #: 1450
Near Paris - France
I've read somewhere on the site that you don't need too light a flywheel on turbo applications.
As I can't find where, maybe it is BS (had to do with low speed working of the engine)
If you rework your combustion chamberss as per Vizard (no reason why not) then you need skimming back or less skimming and less dish in pistons (probably cheaper too)
Or you can talk to benross to put money where power is made (head)
Rusty by nature
