| Home > Help Needed / General Tech Chat > carb conections | |||||||
![]() 384 Posts Member #: 4215 Senior Member |
27th Dec, 2009 at 11:26:56pm
hi everyone
Edited by c2_mad on 27th Dec, 2009. |
28th Dec, 2009 at 09:36:16am
Have a search, there is a pic (I think by Turbo Dave) that shows how to connect it up. On 11th Feb, 2015 robert said:
28th Dec, 2009 at 01:58:18pm
i have searched high and low... but didnt find what i was looking for.. i did find one pic that helped me make the conections already made in the pic, but i still dont know what to do with the rest.. any help is much apreciated.
28th Dec, 2009 at 02:20:00pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
28th Dec, 2009 at 02:54:11pm
your a star mate.. i had already found the first threed, but the second one is much better...
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
28th Dec, 2009 at 03:50:36pm
The yellow connection is the Vac advance for the Dizzy "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
31st Dec, 2009 at 05:16:40am
great... thanks mate. |
29th Sep, 2010 at 04:51:12pm
hi everyone, i know this is an old thread, but i have a question(probably a stupid one) is there a reason why i cant take the vac feed for my dump valve from the outlet with the orrange circle in the pic? i ask this because i noticed a carb spacer on mini spares with a niple for this purpose and that sits just a bit in front of this outlet, and since there is nothing between the spacer and the part where the oullet is, its seems logical to me... but what do i know... |
29th Sep, 2010 at 09:13:26pm
as long as its on the engine side of the butterfly then yes, it should be fine. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
29th Sep, 2010 at 10:11:21pm
thats what i thought... but thought i would confirm as i have never seen any body say that its possible.... |
30th Sep, 2010 at 07:59:06am
No you can't.
78 Posts Member #: 9073 Advanced Member Edinburgh |
30th Sep, 2010 at 09:04:02am
You'd need to check the HIF44 but on the HIF38 that take off is
30th Sep, 2010 at 10:11:25am
hi guys...
30th Sep, 2010 at 10:30:41am
It is just on the manifold side of the butterfly on an HIF44 (I've just looked at one too)
30th Sep, 2010 at 04:32:31pm
oh ok... thanks for your insight rod s... i gues there is no harming in trying it out and seeing how the dump valve works then? |
