Home > Technical Chat > mpi engine removal
nick1275
Member #: 1615
Ferndown, Dorset
starting to strip down an mpi this week for a full resto, anything to watch out for when removing the engine?
done loads on carb'd minis but never an injection one
secondly any recomendations an fd choice? ive got a spare 3.44 but not sure if this is overkill or a 3.1 would be better suited taking into account it will do very little motorway work
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
Carl
Member #: 95
liverpool-on-sea
few more wires so you might wanna lable stuff.
fuel pressure higher watch you dont get a squirt of petrol in ya eyes when you undo fuel pipes.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
be careful with the crank and cam sensors - you can easily damage them.
Other than that all the wires and plugs are fairly obviously colour coded/routed so a few labels and you'll be ok with them.
Other than that its the same as any other mini engine.
Alex
AlexF
MrOz
Member #: 5007
Crazyhill, Livi
Yeah, unleaded in the eye is a tad painful. I'd suggest removing the fuse from the fuel pump and start it up before disconnecting the fuel lines.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi."
If I had a tenner for every time some one has damaged the cam sensor removing the engine, not knowing it was there.
oh and very little motorway driving? go with the 3.44 FD*happy*
Edited by Sprocket on 29th Dec, 2009.
nick1275
Member #: 1615
Ferndown, Dorset
cheers for the replies lads, all out now and no probs almost nailed the cam sensor!
took loads of pictures to remind me when it all goes back in too.
the 3.44 is very tempting
Hmmm weberyyy
