| Home > Help Needed / General Tech Chat > lost for words | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
29th Dec, 2009 at 02:32:10pm
i am lost for words now i was under the impression i could put all the metro turbo parts such as the head turbo and car onto a N/A 1275 block now my mini mechanic has told me the pistons will not last |
29th Dec, 2009 at 02:43:54pm
On 29th Dec, 2009 blister said:
i am lost for words now i was under the impression i could put all the metro turbo parts such as the head turbo and car onto a N/A 1275 block now my mini mechanic has told me the pistons will not last the blocks are the same tell him he's a cock unless its a whole n/a block rods and pistons too, then the pistons may not last long...
Yes i moved to the darkside |
29th Dec, 2009 at 02:52:31pm
depends on what you do to the head and how much boost you run
29th Dec, 2009 at 02:57:07pm
What you are saying is the your mechanic say that the standard N/A pistons will not last with boost.
29th Dec, 2009 at 03:25:23pm
I'm going to build my supercharged engine on standard pistons. I'll be putting 12psi through them, with a CR of about 8:1.
29th Dec, 2009 at 06:05:00pm
Is your bottom end rebuilt or are you just throwing your turbo bits onto a used bottom end? On 7th Nov, 2008 Nic said:
29th Dec, 2009 at 08:22:12pm
I'm running 7-10 psi on an engine built in 1970., thats been for nearly two year now, all stock except the 12G295 head (To give me 8.7:1 CR) with correct ignition (via MJ) and correct fuelling. I run a supercharger and I don't care the TB is on the wrong side.
30th Dec, 2009 at 05:19:38am
I have run with standard MG Midget pistons for two years, using up to 20 psi on one occasion and the pistons have stood up OK. It all depends on how much advance you use, how rich you run it to keep it out of detonation and how long you hold it on full boost. Having said that the pistons have survived 8 runs on a hill climb and a visit to Santa Pod, so they must be reasonable.(did not have a big enough toy allowance to spend £400 on a set of Accralites) |
30th Dec, 2009 at 09:19:28am
as wil has said having the car set up spot on is half the battle, you can have the best gear in the world but if its not bolted together properly and set up properly it will break Crystal Sound Audio said:
30th Dec, 2009 at 12:22:46pm
hello again yeah its a completely standard N/A carb block, 30,000 miles from a metro i got a cylinder head from minispeed, i bought the turbo one and the chambers dont seem any different in size,
30th Dec, 2009 at 12:25:59pm
Ultimately it depends how you are going to use it.
