| Home > General Chat > Is this a good price for a Megajolt Lite Jr kit | |||||||
30th Dec, 2009 at 06:53:45pm
30th Dec, 2009 at 07:13:50pm
No
30th Dec, 2009 at 07:20:11pm
Its just i dont know where to start lol i have been looking on hear its to run my 1380 then if i turbo it its in I have started posting on Instagram also my name on there is turbomk1golf
30th Dec, 2009 at 07:23:45pm
Tom Fenton for pulley machining and cps bracket.
30th Dec, 2009 at 07:25:14pm
thanks mate i will have a look then I have started posting on Instagram also my name on there is turbomk1golf
30th Dec, 2009 at 07:25:24pm
silly question, but then I've never had megajolt...are they com port or usb connection? On 19th Jan, 2010 wil_h said:
30th Dec, 2009 at 07:26:34pm
On 30th Dec, 2009 Jason G said:
silly question, but then I've never had megajolt...are they com port or usb connection? com port |
27 Posts Member #: 4768 Member Shrewsbury |
30th Dec, 2009 at 07:26:50pm
Serial Port (RS232) |
30th Dec, 2009 at 07:27:46pm
30th Dec, 2009 at 07:28:55pm
is a usb version available? i dont think so, however most people use a serial to usb cable without issues. |
30th Dec, 2009 at 07:31:09pm
USB - Serial converters cost about £3 |
30th Dec, 2009 at 07:32:25pm
if i get one is there any where you can take it to get it maped as i am a pc mong I have started posting on Instagram also my name on there is turbomk1golf
30th Dec, 2009 at 07:35:45pm
It depends on how much you are prepared to do yourself.
30th Dec, 2009 at 07:38:47pm
Here you go mate:
857 Posts Member #: 1778 Post Whore Northants |
30th Dec, 2009 at 07:40:16pm
On 30th Dec, 2009 madmk1 said:
if i get one is there any where you can take it to get it maped as i am a pc mong Most rolling roads will be able to map it for you. Edited by sturgeo on 30th Dec, 2009. |
30th Dec, 2009 at 07:40:36pm
so i know this has most likely done to death on here but is megasquirt better then for what i want I have started posting on Instagram also my name on there is turbomk1golf
30th Dec, 2009 at 07:42:08pm
megasquirt offers a higher resolution ignition table (more values to set so greater control), depends what you want to do with the engine in the long run? |
30th Dec, 2009 at 07:47:23pm
well its a new 1380 at the mo and in the long run i may turbo it so not two sure at mo as working out the cost. But i like the thought of the modern side of it ie no dizzy and coil I have started posting on Instagram also my name on there is turbomk1golf
30th Dec, 2009 at 07:50:49pm
so i know this has most likely done to death on here but is megasquirt better then for what i want For just ignition, it will do exactly the same as Megajolt. Maybe a little bit better as it has TPS and MAP as standard so you don't have to worry about chosing which. However, even without the fuel injection components installed, it gives you a whole lot more monitoring of other variables (coolant temperature, air intake temperature) and logging facilities so you can build your ignition map accordingly. But obviously I'm biased :) HOWEVER, I stress, it is much more DIY than a MJ kit. Schrödinger's cat - so which one am I ??? |
30th Dec, 2009 at 07:54:26pm
thank you rod for that i will have a look for one all built up then lol I have started posting on Instagram also my name on there is turbomk1golf
31st Dec, 2009 at 06:24:13pm
or you could look on ebay for example
Edited by philc on 31st Dec, 2009. |
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
31st Dec, 2009 at 10:22:37pm
ive just bought all the ford EDIS parts, coil pack, sensor and unit with all wiring ect for £37 posted off ebay. with the jolt being 63 odd quid im looking at £100 ish for the full setup Edited by MONSTER HEDGEHOG on 31st Dec, 2009.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
31st Dec, 2009 at 10:27:23pm
i need to have more of a look on ebay I have started posting on Instagram also my name on there is turbomk1golf
31st Dec, 2009 at 10:50:52pm
EDIT. NO WAY THATS THE ONE I JUST BOUGHT IN THE ABOVE LINK, THE STUFF IN THAT PICS SITTING ON MY KITCHEN TABLE RIGHT NOW I run a supercharger and I don't care the TB is on the wrong side.
