| Home > Technical Chat > What grit to finish inlet ports | |||||||
31st Dec, 2009 at 07:13:25pm
As title really?
I seriously doubt it! |
31st Dec, 2009 at 07:50:41pm
I'm of the Vizard school of taught and finish them rough with 80 grit to try help keep fuel in suspension, this in turn IMO reduces top ring land power loss due to raw fuel cylinder wall wetting. there is theory to support that a very finely polished port flows more but its not all about flow,
On 17th Feb, 2009 Rob H said:
31st Dec, 2009 at 08:32:12pm
I used about 80 grit iirc AlexF |
2nd Jan, 2010 at 10:08:45pm
use a brick on edge. |
3rd Jan, 2010 at 01:34:43am
regular house brick carl or breeze block? "Turbo's make torque, and torque makes fun"
3rd Jan, 2010 at 09:48:09am
london brick, |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
3rd Jan, 2010 at 11:38:01am
replace the b with a p Everyone knows that instructions only have to be read if the thing doesn't work....
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
17th Jan, 2010 at 03:18:10pm
From start to finish with Diamond tip chip breaker rotary burrs to keep it as rough as possible. Edited by Mr Joshua on 20th Jan, 2010. Own the day
17th Jan, 2010 at 07:43:38pm
Pour some grit sand into the carb whilst running this method will ensure good even porting! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
