| Home > Help Needed / General Tech Chat > boost guage | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
3rd Jan, 2010 at 06:44:55pm
I know you can take your boost guage plumbing from the inlet manifold but i have my servo plumbed to there so where is the next best place to plumb from? can i tee off the pipe that goes from the turbo to the actuator or is this only good for a bleed valve?. |
3rd Jan, 2010 at 07:31:14pm
This has been covered s many times...
In the 13's at last!.. Just |
4th Jan, 2010 at 08:24:56am
The boost gauge needs to be on the engine side of the butterfly. The actuator should be the other side so don't 'T' into that pipe. http://www.twin-turbo.co.uk
4th Jan, 2010 at 08:28:11am
Do you have a dump valve? you could T into that. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th Jan, 2010 at 05:00:22pm
i do have a dumpvalve ill t into that then. The only reason i asked was because i read something someone had put on here and they said you should not put the boost guage on the same pipe as servo as it can course bad readings?. |
