Home > Help Needed / General Tech Chat > just measured my CC in the cylinder head now need help!
blister
Member #: 2590
Croydon
just measured my CC in the cylinder head chambers and now need to work out my overal CR
cylinder bore size = 70.60
piston stroke length = 81.30
head gasket bore diameter =
Compressed Head Gasket Thickness=
Combustion Chamber Volume In CCs = 22-22.5cc
Piston Dome Volume In CCs=
Piston Deck Clearance =
how do i go about finding out the rest? look around the internet for a very long time
the engine is a standard 1275 metro and the head was from a "turbo" mini
Advantage
Member #: 1450
Near Paris - France
There are graphs in the Vizad book regarding he gasket stuff.
For the dish in the pistons you can either measure it as for the head or calculate it from your engine blueprints.
If it is a 9.4 CR 1275 engine and as it must have had a 21.4cc head, single cylinder capcity divided by CR minus 1 if I recall correctly but do your homework and it should be OK.
Maybe save piston to deck clearance as a safety margin if you turboing this, that's what I would do ...
Rusty by nature
blister
Member #: 2590
Croydon
yeah it will be turbo'd just going to get the vizard book its on a shelf really high up wrapped in a cloth *happy* lol brb
blister
Member #: 2590
Croydon
so what are engine blueprints? all the specs? shall i get my engine number as well?
I agree, I never include ringland or deck volume as a margin. Better to be low on a turbo engine.
Basically to use that head as it is you need 18cc dished pistons to get the CR below 9:1
blister
Member #: 2590
Croydon
i got a cd case and put it onto the face of the cylinder head and syringed water in only on one chamber, and got 22.5
i have standard 1275 pistons
12HA83AA
blister
Member #: 2590
Croydon
wow this has got very confusing now reading david vizards book and its not making much sense :(
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
http://www.afracing.com/CR.xls
Hope that helps!
AlexF
blister
Member #: 2590
Croydon
with that excel i got
bore : 70.61
stroke : 81.40
gasket volume : 4cc
ring land vol : 0.78
piston vol : 6cc
head : 22cc
deck vol : 5.25
this gave me a ratio of 9.38:1 this sound right for a standard 1275 metro with a 22cc head?
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
from memory a std mety turbo is 9.5 to 1 but its early in the morning and i havent worked your maths out so if you havent added 1 to your end figure to account for atmospheric air pressure then you could be in trouble as an mg engine is 10.5 to 1.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
Your calculation is right, but where has a deck volume of 5.25cc come from, that's quite big.
Standard Metro 1275 should be 9.4:1 iirc
no, actualy its 9.44:1
*tongue*
*tongue*
*Shooting*
blister
Member #: 2590
Croydon
it was already on the excel software as standard for a N/A 1275
By this I guess you mean the deck volume?
This is a hell of an assumption, you need to measure it on your own engine. On all my engines it's zero.
blister
Member #: 2590
Croydon
yes wil_h sorry about that yeah the deck volume was already inputted in the excel software
mowog
Member #: 6792
The ONLY way you will find out with any remote accuracy is to measure it. I see that you used water previously, however this will give you some in-accuracy because it has surface tension. The most accepted way is to use Kerosene (or similar).
By measuring it, it take in to account production tolerances, production changes and any machining tolerances.
Cheers.
