| Home > Help Needed / General Tech Chat > very hot mini!!! | |||||||
66 Posts Member #: 421 Advanced Member nr newark lincolnshire |
4th Jan, 2005 at 09:57:19pm
HI |
4th Jan, 2005 at 10:23:34pm
yes its all fairly normal!
AlexF |
4th Jan, 2005 at 10:25:46pm
Hi Mike..
4th Jan, 2005 at 10:35:37pm
Ok i shall try that with the exhaust.
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
4th Jan, 2005 at 10:36:20pm
What boost are you running ? Running high boost and caning it will often see the Turbo glowing, but i've never seen it happen on standard boost.
Edited by Turbo Phil on 4th Jan, 2005. |
4th Jan, 2005 at 10:37:05pm
Red exhaust is too far retarded.
4th Jan, 2005 at 10:40:42pm
I am running 8 degrese and my mixture is 4.5 co on the MOT computer at tick over.
4th Jan, 2005 at 10:42:39pm
Mikes minis -You must have just posted while i was typing the last one.
4th Jan, 2005 at 10:45:28pm
Timing is 8deg btdc ?at 1500 rpm vac advance removed ? Mark your pulley up, and check advance with rpm. See what it's like at 2000, 2500, 3000 etc
4th Jan, 2005 at 10:51:25pm
yea it goes flat at about 5500. what sort of timing figgers shall i go for.
4th Jan, 2005 at 10:52:25pm
sorry bit slow at typing. |
4th Jan, 2005 at 11:57:11pm
yup pretty sure detonation and pinking (pre-igntion) are the same things, although i'm probably wrong for a change On 20th Oct, 2015 Tom Fenton said:
5th Jan, 2005 at 02:30:56pm
im the worst person on here to say this but get it all rolling roaded by a good place do a search on here and some recommended rolling roads should show up, if you cant afford that do a search on here about what to set your timing to i think theres some advise about setting it at 5000 revs or sommot (cant remember exact ).
5th Jan, 2005 at 04:24:55pm
Mikes minis, hi Edited by BENROSS on 5th Jan, 2005.
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
5th Jan, 2005 at 06:37:42pm
most important is to check tdc is actually lining up with the timing mark on the pulley (pulley is two piece and can move round ), or set from flywheel if marked ,
5th Jan, 2005 at 06:49:48pm
Mike,
6th Jan, 2005 at 10:48:20pm
hi again
7th Jan, 2005 at 11:35:33am
Right Again Dave
8th Jan, 2005 at 01:05:46pm
mine wouldnt start when it was hot, it was the float jet thing in the carb was faulty, it would only start when i turned off the fuel pump, dont know if this helps, but i thought id suggest it |
