| Home > Help Needed / General Tech Chat > Swapping and cleaning Spot Welder Tips | |||||||
6th Jan, 2010 at 05:56:45pm
I need to do a fair amount of spot welding on the mini's shell this week and want to fit the dog legged tipps for better access.
6th Jan, 2010 at 06:06:07pm
On my SIP, all the electrodes (tips?) are held in with cotter pins, just like oldskool bikes, so I just tap them backwards on their taper, usually with a wooden block on the other side to support the main arm(s).
6th Jan, 2010 at 06:12:27pm
Thanks Rod. Mine is a SIP too.
6th Jan, 2010 at 07:07:19pm
You can use anything to clean spotweld tips. File, hand grinder, bench grinder.....whatever. Just make sure they line up and the tip face is parallel on the metal. :) On 19th Jan, 2010 wil_h said:
6th Jan, 2010 at 07:09:06pm
6th Jan, 2010 at 07:13:48pm
I used to cheat...make sure the spot welder is off...stick a file between the electrodes with them closed. On 19th Jan, 2010 wil_h said:
6th Jan, 2010 at 07:14:42pm
and if the welder is on....
6th Jan, 2010 at 07:21:00pm
I would start up another welding post...but you have to be a complete retard not being able to spot weld. On 19th Jan, 2010 wil_h said:
6th Jan, 2010 at 07:46:35pm
The file makes sense.
6th Jan, 2010 at 10:13:43pm
Just do a test piece...try twisting & pulling the two bits of metal apart. If the middle of the spot weld from one piece stays on the other piece of metal, then you know you've got it spot on. On 19th Jan, 2010 wil_h said:
7th Jan, 2010 at 09:12:51am
I should be fine. My replacement parcel shelf hasn't fallen of yet... On 11th Feb, 2015 robert said:
