Home > Help Needed / General Tech Chat > renault 5 actator
nibble36
Member #: 4273
stoke on trent
hi all iv been offerd a renault 5 actator and been told it boost to 12/14psi would this be ok to use on my t3 instead of the standard one of 4psi
any help would be greatfull thanks nibble
I guess you mena actuator?
You would need to modify the T3 bracket as the R5 actuator is a different design, not sure if the rod is the right length or thread either. Better to just buy the right type.
nibble36
Member #: 4273
stoke on trent
opps yes actuator
lol
If you want a cheap uprated T3 actuator, look out for Sierra Cosworth standard actuators. The Cossie boys commonly upgrade, but the standard one is good around about 10psi.
turbominivanman
Member #: 1504
Westbury, Wiltshire
As Tom says, I also use the Cossie T3 actuator.
I think the Garret part number is 430099-18.
The '-18' part (or for that matter, whatever dash number you have) - if you divide by two, you get the actuator spring pressure.
So a '-18' is a 9 psi actuator and a '-32' is a 16 psi actuator.
I think (?!).
Richard.
