| Home > Help Needed / General Tech Chat > Long shot got some rover 600 brake problem | |||||||
![]() 368 Posts Member #: 362 Senior Member durham area |
6th Jan, 2010 at 10:26:36pm
all gone down hill with me dads 1998 rover 600 diesel, problem is with the engine off brake pedal feels good nice and hard as you would expect, start the engine the pedal goes down a little, now if you sit with your foot on the pedal it drops right to the floor, we have just bled the system and fitted a new master cylinder and still have the same problem, just cant get me head around it any help much appreciated (its got ABS to if that makes much of a difference) love that straight cut scream!!!
6th Jan, 2010 at 10:55:03pm
Sounds like a problem with the brake booster or vacuum pump
Edited by Sprocket on 6th Jan, 2010. On 26th Oct, 2004 TurboDave16v said:
6th Jan, 2010 at 10:56:29pm
filling the servo with brake fluid? master cylinder failure or an abs fault. if you can be arsed bypass the abs pump with straight through fittings to rule it out. but i would be tempted to try a new master cylidner, or even just a scrappy one to rule tha tout. turbo 16v k-series 11.9@118.9 :)
7th Jan, 2010 at 05:16:17pm
as a say we spent last night fitting a new master cylinder and its still the same servo works fine or as it should but if you keep your foot on the brakes it goes right to the floor no leaks any where and has had a good bleeding. love that straight cut scream!!!
7th Jan, 2010 at 06:01:42pm
5lts of unleaded and a match will sort your Rover problem Crystal Sound Audio said:
7th Jan, 2010 at 06:11:53pm
On 7th Jan, 2010 wolfie said:
5lts of unleaded and a match will sort your Rover problem Steady on!! 5 litres is a bit much!! On 26th Oct, 2004 TurboDave16v said:
7th Jan, 2010 at 06:16:12pm
Why not just put a wragg in the top of the tank and save yourself £6 On 11th Feb, 2015 robert said:
7th Jan, 2010 at 07:03:33pm
most liekly abs related then if you have no leaks ! turbo 16v k-series 11.9@118.9 :)
