| Home > Help Needed / General Tech Chat > silicon or alloy t piece needed can't find any | |||||||
6th Jan, 2010 at 11:03:25pm
Hi lads I am looking for some thing like this for my water pump so I can T off to the heater. It needs to be 19mm with a 13mm T hope someone can help.
Edited by madmk1 on 6th Jan, 2010. I have started posting on Instagram also my name on there is turbomk1golf
7th Jan, 2010 at 08:52:41am
Merlin, Trident Demon Thieves all do reducers - usually you can get a hose that changes diameter to do this job rather than a reducer. This way the hose can connect to the pump say! On 5th Sep, 2011 Vegard said:
7th Jan, 2010 at 02:10:34pm
central heating piping more than up to the job if you have it lying around Yes i moved to the darkside |
72 Posts Member #: 6792 Advanced Member |
9th Jan, 2010 at 04:46:12am
Why not Grab yourself a piece of 1" (25mm) copper tubing and another piece of 1/2" (12.7mm) copper tubing and make one. Don't solder it though, silver solder or braze it. Easy, that's how I do mine. |
