| Home > Help Needed / General Tech Chat > Post Welding | |||||||
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
8th Jan, 2010 at 05:52:51pm
Hey guys,
1972 998 TURBO SLEEPER |
8th Jan, 2010 at 05:58:45pm
depends what joint it is,
8th Jan, 2010 at 06:02:25pm
Thanks for the help, im going to be welding the bulkhead box in. 1972 998 TURBO SLEEPER |
8th Jan, 2010 at 06:03:05pm
I give every thing a good coat of zink primer, then seam seale the joints that are going to/could get wet (like the roof gutters, floors etc etc). Probably worth doing it to the bulkhead box in and out On 11th Feb, 2015 robert said:
8th Jan, 2010 at 06:05:49pm
8th Jan, 2010 at 06:11:48pm
Cheers guys, ill be placing an order with Frost ASAP. 1972 998 TURBO SLEEPER |
8th Jan, 2010 at 06:16:35pm
btw seam sealer can be a bit messy, it may be worth getting it in a tube...
![]() 83 Posts Member #: 7115 Advanced Member essex |
8th Jan, 2010 at 06:19:29pm
Yep I find it much easier with the tube as it doesn't get everywhere! |
8th Jan, 2010 at 06:19:31pm
8th Jan, 2010 at 06:32:54pm
On 8th Jan, 2010 mini13 said:
btw seam sealer can be a bit messy, it may be worth getting it in a tube... http://cgi.ebay.co.uk/Car-Body-Panel-Joint...=item3ef023268e You really should have told me that on Wednesday.... On 11th Feb, 2015 robert said:
8th Jan, 2010 at 06:37:23pm
LOL On 28th Aug, 2011 Kean said:
8th Jan, 2010 at 06:46:40pm
I guess I'll be masking my roof etc up then.
8th Jan, 2010 at 07:19:28pm
If the car is stripped, you could try fitting the box from the inside the car. Then from the engine bay side, weld the box corner to corner. Might look neater too rather than those big flanges on show. On 19th Jan, 2010 wil_h said:
8th Jan, 2010 at 07:22:41pm
the inside is stripped bare, i was planning to weld from the inside. also it will hide most my pup welding lol
8th Jan, 2010 at 07:34:54pm
On 8th Jan, 2010 longy said:
the inside is stripped bare, i was planning to weld from the inside. also it will hide most my pup welding lol If it's anything like my welding, then it's nothing an angle grinder can't sort out
