| Home > Help Needed / General Tech Chat > Exhaust down pipe | |||||||
567 Posts Member #: 102 Post Whore Pennsylvania USA |
6th Jan, 2005 at 01:22:38am
Hi |
6th Jan, 2005 at 08:01:02am
I hate this job. You shoud try doing it on a 998 block, the clamp barely fits between the joint and the block.
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
6th Jan, 2005 at 08:42:59am
Make sure you have the clamp the right way up, the hole is bigger on one side.
6th Jan, 2005 at 10:21:10am
Cheers guys I'll give that a go. |
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
6th Jan, 2005 at 11:27:58am
i find light pressure from a jack beneath the downpipe holds it up against the outlet while tightening , use exhaust paste on sealing faces and in the groove around the clamp as it holds it in place once dry, and use the steady bracket to the 'box to avoid the joint being moved while in use , another general tip is weld the bolts in one side of the clamp so you dont need a spanner on one end |
6th Jan, 2005 at 03:45:49pm
This has been mentioned before colas,
