| Home > Beginners Tech > Vac hoses | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
11th Jan, 2010 at 12:56:55pm
Its time to plumb in all my vac hoses and I was just after a little advice/confirmation. At lot of the stuff I have found while searching have mentioned taking a reading from the manifold where the survo takeoff is, i'd rather avoid that if I can.
11th Jan, 2010 at 01:05:51pm
megajolt, boostgauge and dumpvalve all want to be off the manifold
Edited by Brett on 11th Jan, 2010. Yes i moved to the darkside |
11th Jan, 2010 at 01:12:38pm
On 11th Jan, 2010 Brett said:
there are thread about that discuss having all the inputs T together, Wow
4-5 can be T into the boost gauge but will only read the positive side of atmospheric Edited by Brett on 11th Jan, 2010. Yes i moved to the darkside |
11th Jan, 2010 at 02:17:22pm
Just spoke to a mate and he has the correct pre drilled bolt to fit in the manifold/survo takeoff so I now have that too.
Edited by Simon on 11th Jan, 2010. |
11th Jan, 2010 at 02:31:54pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=323907
11th Jan, 2010 at 03:11:07pm
i really dont fancy drilling my carb, call me a wuss but i'll leave that be for now.
11th Jan, 2010 at 03:39:08pm
I ran my boost gauge and Mj off the brake servo fiting, I just drilled and tapped it 1/8bsp and bought a barbed fitting for it.
11th Jan, 2010 at 04:15:07pm
On 11th Jan, 2010 matty said:
I might be wrong, but im sure I Tee'd my boost gauge into the actuator signal hose? that would give just positive reading aswell Yes i moved to the darkside |
12th Jan, 2010 at 10:08:28pm
Just thinking, I have replaced the bolt that goes off to the survo with a banjo bolt with a hole in the top.
13th Jan, 2010 at 08:09:05am
The genuione metro turbo drilled/tapped take of bolt that we used on the metro van took a 1/8 BSP fitting. I got one of ebay for a few quid. On 11th Feb, 2015 robert said:
13th Jan, 2010 at 08:42:30am
cheers for that, good ol ebay, i'll have a look.
13th Jan, 2010 at 09:25:15am
fitting it on the servo banjo imo should be ok your only on the brakes when your not on the gas...
13th Jan, 2010 at 09:30:18am
I would have thought if there is a one way valve in the servo piping then it shouldn't matter. If something is worth doing, it's worth doing half of. |
15th Jan, 2010 at 12:22:21pm
I've got all the bits delivered today to modify my carb spacer to have 2 vac hose take offs.
16th Jan, 2010 at 01:23:11pm
This was my final soultion.
Edited by Simon on 16th Jan, 2010. |
16th Jan, 2010 at 01:52:41pm
http://www.youtube.com/watch?v=YKUOB8MN4Kc&feature=related
16th Jan, 2010 at 02:11:54pm
