Home > Help Needed / General Tech Chat > Cutting Internal Keyways
sturgeo
Member #: 1778
Northants
How do you cut keyways into pulleys for example?
I've found a site that sells broach's and bushings and understand that you can use a press but how do you attach the broach to the press?
http://www.mscjlindustrial.co.uk/CGI/INSRC...94966389%201356
sturgeo
Member #: 1778
Northants
Youtube has the answer:
http://www.youtube.com/watch?v=8tAz5YDFtAs
I think he needs to bolt it down though!
Any decent machine shop should have a broaching machine, just make sure you give them the bits you want to fit to gether so they can make sure they fit *wink*
hacksaw and file.
Edited by robert on 11th Jan, 2010.
I love the way he says that the broach is very brittle on several occasions and then bangs it on the work bench to get the swarf out of the teeth :)
He's putting together a list of tools for me to invest in, including a CNC milling machine :(
I want to retire before I reach 60 - no chance.
youll be much busier after you retire paul .THIS is the holiday ..
tadge44
Member #: 2500
Buckinghamshire
Damn right !!!
You need to add a shaper to your shopping list.
the cutter sitd in a guide , this holds it in the right place within the borem yoiu then simple push the cutter through with a press of a large hammer ,
or as i do use my slotting machine,
A nice hydraulic press would suit the broach kit you (Paul) are about to buy perfectly.
Preferably a motorised pump, so much easier to control than the manual pump ones.
sturgeo
Member #: 1778
Northants
Well I was looking at a arbor press and was going to purchase it myself but he decided that a larger hydraulic press was more suitable because we can use it for more things.
Matty, where does a shaper come into it?
I used a shaper to cut my keyways out. We used it to cut the keyway to size then finished off with a file to get a good fit with the key...thats where a shaper comes into it. *wink* A shaper has soo many uses. lol
I utilised what tools I had (read as my mate had) and worked well.
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
Why did they get Jimmy stuart to act in that vid? *hehe!*
