| Home > Help Needed / General Tech Chat > Engine steady | |||||||
157 Posts Member #: 6496 Advanced Member Somerset |
13th Jan, 2010 at 07:56:59pm
Is the one on the gearbox really needed? On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair |
1425 Posts Member #: 690 Post Whore Norfolk |
13th Jan, 2010 at 08:46:02pm
yes! in fact my preffered method of engne torque reaction restraint is to use two on the lower rear of the subframe to gearbox - minispares kits, the one at the front ofthe gearbox as std then the conventional side mount from the engine block. If you restrain the engine just at the top the motor can pivot around its "torque axis" under torque application causing the bottom of the motor to move on the subframe engine mounts - which appear very stiff at first glance in compression but are also very soft in shear (fore aft in car)
If Carling made Mini engines
13th Jan, 2010 at 09:01:58pm
13th Jan, 2010 at 09:04:48pm
I recomend using 4 steadys, 2 at the top of the engine and 2 at the bottom going backwards, personally I leave the std one that goes forwards off, as i feel it fights the other bottom ones, but thats just me, what ever you do, ypou need somthing on the bottom. On 28th Aug, 2011 Kean said:
