Home > Help Needed / General Tech Chat > on the road
T3nhp
Member #: 7922
Right since my last post mini is now on the road as of today!!!
i have some questions
1) oil pressure is running when warm about 26-27 psi is this too low?
2) when accelerating boost builds i can hear the turbo wistle but when revs get really hi i hear a loud hi pitched wistle similar to the dump valve but higher pitched could this be a leak from somewhere? or the dump valve itself?
3) i know its running ritch, but there is a judder in low revs could it be the fuel mixture or low oil pressure maybe?
wicked site any ideas would be great!
T3nhp
ok,
if thats 26-27 psi at idle or low revs thats ok, by about 3000 rpm you should be seeing about 40-45 psi.
if the boost has been wound up the whistle could be the std metro "dump valve" if you can call it that. on the plenum under the incoming pipe there is a ball and spring to vent excessive boost.
the judder could be any number of things, best bet would be to get it on a rolling road. an hour with someone good will show up any issues.
T3nhp
Member #: 7922
just what i needed to know thanks! and yea 26- 27 psi is low revs and idle!
V - MAX scart here i come
check the timing if possible, and stay of the throttle incase you melt anything *wink*
