Home > Help Needed / General Tech Chat > Waterpump gasket?
Wile E. Coyote
Member #: 7893
Portsmouth
Hi all :)
I am renewing the waterpump gasket, this one;
http://www.minispares.com/Product.aspx?ty=pb&pid=34616
And it says "genuine water pump gasket -red one side and grey the other-grey side to the block"
If i put the grey side to the block, it doesn't fit at all, the only way it fits on the waterpump is with the red side to the block ........
Any chance this could be a odd one out?
Edited by Wile E. Coyote on 14th Jan, 2010.
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
And would it be ok to put the grey side to the waterpump?
Jamie.
Is there a difference in the material on each side? I stand to be corrected, but I can't really see it making any difference tbh.
Ive always used a plain gasket with a smear of RTV sealant on each side.
Edited by matty on 14th Jan, 2010.
Wile E. Coyote
Member #: 7893
Portsmouth
Hey Matty,
Cheers for reply :0)
Yeah, one side was gasket, and the other almost had a raised layer on it (the block side part)
I put it on the way it fitted in the end, with some Gasket seal, but, it definiately wasn't the correcy way according to Mini Spares info.
Jamie.
t3gav
Member #: 229
Gavin@minispares.com
kent
I've changed our description now, all genuine water pump gaskets fit the way you have fitted yours.
Wile E. Coyote
Member #: 7893
Portsmouth
Oh brillaint,
Cheers Gavin, i did wonder, and was going to ring up and say, saves that phones call now, Cheers again.
*smiley*
Jamie.
