| Home > Technical Chat > supercharger anti-ice carb filter - opinions please gents. | |||||||
![]() 89 Posts Member #: 7165 Advanced Member Solihull/Birmingham |
14th Jan, 2010 at 11:12:23pm
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
14th Jan, 2010 at 11:47:51pm
i wouldnt bother, if you do get carb icing then simply spend £5 on some 8mm copper fuel line and wrap it round the manifold next to the carb then plumb that into the cooling system, job done.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
15th Jan, 2010 at 06:09:34am
I wouldn't think that'd work would it Hedgehog?
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
15th Jan, 2010 at 08:11:57am
It seems to be a fundamental design flaw with thes SC setup, an anti-icing solution appears to be needed in most cases.
15th Jan, 2010 at 08:24:42am
In Norway, most cars were fitted with a carb heater. I always bin them, but that might be beneficial?
15th Jan, 2010 at 08:44:54am
My old college tutor ran a Beetle with suck through T3 and ran a small hose into the choke blowing warm air from the heater - easy, and it can be switched off when more power is required like track days I seriously doubt it! |
15th Jan, 2010 at 06:24:09pm
as far as im aware the main reason you get carb icing on these installs is because the carbs so far away from the cylinder head that it doesent get any real heat put into it, the fact that your geting the air from the coldest place available doesent help maters but it dont think its the main/only reason.
Edited by MONSTER HEDGEHOG on 15th Jan, 2010.
