| Home > Help Needed / General Tech Chat > Falling at the last hurdle (engine block drain plug) | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
16th Jan, 2010 at 08:38:11pm
god dammit! nothing goes as you expect it with a mini does it, in a way i should come to expect that, hmm, im sure that makes sense.
Edited by Simon on 16th Jan, 2010. |
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
16th Jan, 2010 at 08:47:04pm
im going to go out on a limb and say try a std temperature sensor or it could be the same thread as an mg manifolds servo takeoff bolt.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
16th Jan, 2010 at 08:58:13pm
the std temp sensor was the first thing i tried too, but its smaller than that.
16th Jan, 2010 at 09:03:42pm
our van has this bung too. deffo early a+ blocks If something is worth doing, it's worth doing half of. |
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
16th Jan, 2010 at 09:12:13pm
Cant remember the part number but they are available from Halfords, same size as one of the sump plugs. |
16th Jan, 2010 at 10:00:48pm
On 16th Jan, 2010 advantage998 said:
Cant remember the part number but they are available from Halfords, same size as one of the sump plugs. now that sounds good, halfords will be open tomorrow, any more details from anyone? |
17th Jan, 2010 at 11:37:54am
If it's the same as the "A" blocks, the thread is so close to 7/16" UNF that it makes no difference.
