Home > General Chat > cage fitting
jpboost
Member #: 29
Croydon
Hi
I've been out of the mini scene for a while, but am resurrecting my old mini van project. I am going to be fitting a rollcentre miglia cage in the near future (modified/extended cage already ordered)
With mini's what do you guys normally do for the welds on the very top of the cage ? roof off, or drop the cage through the floor? Or do you run the main hoop sufficiently low enough to just about weld round to the top from inside?
Looking through the build threads, (and the lack of pictures of cars with the roof's off) I'm assuming most of you drop the legs through the floor?
Edited by jpboost on 18th Jan, 2010.
Too many projects!
Prawn
Member #: 5232
basingstoke
From what I've seen, many people going as far as fitting a full weld in miglia cage seem to go for composite roofs too.
i think it's a case of if you're having a carbon roof it's so simple do just finish the welds with teh roof off, but otherwise, you're left with no choice but to drop it through the floor then box it in really....
Scruffy
Member #: 328
Seaford Rise, South Australia
Does the cage sit on boxes? If so you tack the cage together and then take out the boxes allowing it to drop 3 inches - this allows you to weld the top joints. That is what was done with mine anyway!
Edited by Scruffy on 18th Jan, 2010.
On 5th Sep, 2011 Vegard said:
Here's what I did:
Sadly the roof warped slightly what I welded it up again, so I'll probably put a CF skin over the top (regs state that I have to keep the steel roof)
Rob you horrible horrible butcher
GET OUT!!
jpboost
Member #: 29
Croydon
lol. I certainly won't be cutting a letter box in the roof. I don't know about 'Butcher', but it's certainly an effective way of getting the job done !!
I'll see if the cage has boxes on the bottom when it arrives... If not, I'll be going for the holes in the floor option...
Too many projects!
Rob you could have put on a chav box roof scoop vent *laughing*
rosco454
Member #: 5222
Northumberland
GET OUT!!
Great reply! *hehe!*
it was good of you to show us Ro... even if most on here are horrified of what you have done :p *happy*
It would distort less if the hole was round - Useless fact for the day
Paul
Paul
how big is your hole saw darling?
*happy**happy*
how saw is your hole darling?
*surprised*
Edited by apbellamy on 19th Jan, 2010.
three cocks wide??
how about putting a scoop over the hole
On 18th Jan, 2010 Rob H said:
Here's what I did:
