| Home > Help Needed / General Tech Chat > mpi wont start | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
18th Jan, 2010 at 05:59:22pm
my mrs went to go out in her car earlier and nothing! its a 1998 mpi.
18th Jan, 2010 at 06:35:50pm
19th Jan, 2010 at 04:33:42pm
the relays and fuses are all fine, it seems it could be the starter? put a screwdriver across the terminals and there was only a little spark and it didnt spin over.
928 Posts Member #: 65 Post Whore South Yorkshire |
19th Jan, 2010 at 05:00:08pm
I found with ours that electrics would work even if the battery didn't have enough charge to turn the starter. I would double check your battery or try a jump start before taking it to bits. |
19th Jan, 2010 at 05:47:19pm
mine clapped out one day, it was one of the big green engine compartment fuses. though you say you have checked these.
Edited by welshdan on 19th Jan, 2010. |
19th Jan, 2010 at 06:02:25pm
green fuses are all ok, the battery is on charge now, so will see what happens tomorrow! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
20th Jan, 2010 at 05:48:08pm
still nothing with a fully charged battery, the fuel pump relay on the brake servo is clicking when i'm trying to start it, could this be the fault? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
20th Jan, 2010 at 06:24:56pm
does it have the Rover imobiliser? My sister has a 111 and if its not turned off it just clicks like a flat batt. Edited by gr4h4m on 20th Jan, 2010. I run a supercharger and I don't care the TB is on the wrong side.
20th Jan, 2010 at 06:33:23pm
yeah its got the standard immobiliser, it does turn off, well it seems to turn off.
869 Posts Member #: 2443 Post Whore Cheshire |
20th Jan, 2010 at 07:26:40pm
Whats the engine earth lead like? corroded or snapped? |
20th Jan, 2010 at 07:34:19pm
will check the earth lead tomorrow. thanks,
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
20th Jan, 2010 at 08:23:03pm
your putting the key in the boot lock???
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
21st Jan, 2010 at 06:46:12pm
sod off you! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
29th Jan, 2010 at 04:55:49pm
it was the starter! the wire connecting the solenoid to the starter has rotted away. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
